View Poll Results: What is your gas mileage?(Specify cali or non cali) (Multiple checkboxes are allowed)
Cali
23.53%
Non-Cali
47.06%
Less than 150 Miles per tank
11.76%
Less than 200 Miles per tank
17.65%
More than 200 Miles per tank
23.53%
More than 250 Miles per tank
35.29%
Multiple Choice Poll. Voters: 17. You may not vote on this poll
So Cal Guys: Gas Mileage (Other regions, get involved too)
Old May 7, 2002 | 07:55 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
I was wondering why my gas mileage is Still bad. Replaced O2 sensor (april), coil, cap, rotor, plugs (all in oct), and wires (about a year old). Is it because we get a different kinda gas than the rest of the country???? Or is it because I do a lot of city driving? I last got 154 miles on a tank, and then filled it up w/ 11.9 gallons.
Old May 7, 2002 | 08:25 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
i get over 300 per tank and thats city driving highway i get over 30 miles per gallon with 202000 miles on the enigne
Old May 8, 2002 | 01:31 AM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
almost 13mpg.. do u do mostly city driving.. brake on.. gas on floor.. brake on?? that would explain ur horible gass milage (i cant really critize ppl that do that, cuz i do it too).. do have an exhaust leak somewhere? that would effect ur milage and performance..
something ive noticed thats helped me in all the cars ive had, run one tank of higher octane gass a month (87 normally, 91 once a month).. its helped me w/ milage in the past..
is cali the only place that has 87, 88.5 (most places around here still label this 89) and 91 octane gas?
-mike (loomdog)
Old May 8, 2002 | 09:28 AM
SAEspinz80's Avatar
after looking at what you've done, def replace the fuel filter if you haven't already. i replace mine, which seemed to be the original, and the gas that was left behind was disgusting.
right now i have MSD 8.5mm wires and the GM balster coil. and after replacing the fuel filter, cap, rotor, ignition module, and o2 sensor (all in trying to troubleshoot a hestation problem) , my gas milage shot up from 125 a tank to 225 a tank city....and 290ish highway.
Old May 8, 2002 | 06:51 PM
89V6FBIRD's Avatar
Oh yea, but the fuel filter is about a year old, and it doesn't even have 10,000 miles on it. So I don't think it would be that.
Yea it's all city driving, once in awhile, I'll take the freeway, only on the weekends though. I usually just put it in Drive, because I never drive faster than 45 mph, and isn't that where it shifts to 4th gear anyway? Once I get on the freeway, I put it in OD. I just wish the mileage would be better, I mean, we do have the smaller engines of the F-Body (excluding 4cyl)
Old May 9, 2002 | 12:00 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
My car is running rich and I still haven't found out why....anyway:
100% City driving--- about 210-220 miles
100% Highway----about 320-350 miles
50/50 driving-----about 250 miles
The city driving is with a heavy foot though. The heavy foot has gotten me into a bit of trouble in the last 3 weeks so I expect my mileage to go up due to me switching to "granny mode".
Old May 9, 2002 | 09:31 AM
Setzer's Avatar
When I first got the car it would do about 350 on highway and about 290-320 in the city. Though, my car has been running rich lately. Though, I do know why. There is a one way check valve that is connected to the air injection by-pass valve. If you dont know what that is it is the part that send Oxygen to the cat and O2 sensor. Well, at least that is how it was explained to me. When the one way check valve goes bad it send hot exhaust through it and burns the bypass valve. SInce the bypass valve is about $150 at the auto parts store and over $200 from the dealer, I havent been able to get a new one yet. So if your car is running rich that could be one of the problems. One way to know is that you will hear a very annoying exhaust noise from under the hood. Well, hope this helps someone.
~Josh~
Old May 9, 2002 | 10:23 AM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
back in the states I would get 300 miles a tank (not running on fumes in the E either), and that was city and highway combined. Over here I get 250 miles, but I'm also driving either city, hilly areas, or hauling @$$ on the autobahn, which is also hilly.
I just can't win
Maybe when I get done with the tuneup it'll get better. I hope
Old May 9, 2002 | 11:13 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Gas mileage? What's that? I fill my tank every 3 or 4 days for local driving, if that helps... maybe 30 miles/day?
Old May 9, 2002 | 11:43 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
infinate mpg in the bird so far
But it has got to be better than the blazer or bonnie around town. The Blazer gets about 15-17 city, yuck. The bonnie, guestameteing less than that. no trip odometer.
Highway milage is better. The blazer gets, on a light load to K-Town, 330 miles on 1 tank(20 gals) of gas going average speed of 69 (shawing). The bonnie, when I drove from Minot, ND to K-Town, TN, driving average speed of 65, up to 450 miles a tank (26 gals) 17 mpg, but still about 8 hrs between fill ups. Both of those highway mpg are sad, so I'm hoping the bird will be a nice step up.
Old May 9, 2002 | 03:42 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
My records are:
-On Celebrity 2.8 V6 with 97 octane gas:
City: 17 mpg
Highway: 30 mpg
-On Corsica 2.8 V6 with 93 octane gas:
City: 17 mpg
HIghway: 25 mpg.
The difference: I think Celebrity has MAF and MAP (SD).
Corsica only MAP (without MAF).
Regards,
Denis V.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Glowsock
Sep 11, 2015 11:09 PM
TBRays98
Sep 6, 2015 05:05 PM
