Power pulleys and high output Alt.
Old Jul 10, 2002 | 09:13 PM
AFrikinGoodTime's Avatar
I tried the install of my 200amp PowerMaster altenator today and the damn thing went up in smoke. Let this be a lesson or reminder for mechanics 101- New parts don't always work just because they are new. Needless to say its on its way back to them for another try. Ill keep everyone posted on the results of my charging statis with the crank and alt. power pulleys when I get the next "new" altenator.
Old Jul 10, 2002 | 09:25 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Ouchy Wouchy....
That was kinda stupid. You must admit....
Old Jul 10, 2002 | 09:26 PM
Camar_Hunter_c's Avatar
Uh 200!?!?! I have a 160 and its just fine...
Old Jul 10, 2002 | 09:29 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I got a 180, and never miss a beat....
Old Jul 10, 2002 | 09:33 PM
Are you running the alt. power pulley and a/c? Because of the ratios it will be turning aprox 110 at idle and 160 at speed with the 200amp unit.
Old Jul 10, 2002 | 09:37 PM
Originally posted by Kj Rockz
Ouchy Wouchy....
Think about what you just said, why would this be stupid on my part if a new part is bad?, now try to graduate from school and ill talk with you when you are educated.
Old Jul 10, 2002 | 10:51 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Ohkhay oh wise and almighty. I'm not so sure it was the part, sometimes it's the dumbass tring to install it...
Dont hide from the truth...
Old Jul 11, 2002 | 12:58 AM
Man chill I'm not flaming.... And no I do not have the power pullies, I am a firm believer in NOT installing the Alt pully for that very reason. I am how ever looking at a crank pully.
Old Jul 11, 2002 | 02:40 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I think duals are beter than one. You have more control on where the juice goes, you can turn one off when not needed and its cheaper.
autozone sells 108 amp alt. for 60 bucks, remove the air pump n put 1 in its place.
216 amp for 120 bucks plus a little labor.
remove the AC and add a third if you want to go deaf.
With that much juice you should have more than 1 batt. and a tip for that is use welding cables for wire. Better and cheaper than what you can buy at a auto/speaker shop for longer batt cables.
same thing on a big rool by the foot.
Old Jul 11, 2002 | 06:13 PM
Joe, I wasn't asking this in the least ill manner. Sorry you may have interpeted it that way. The whole reason for the 200amp alt. is because I'm planning on running both pulleys.
The 200amp alt puts out 140amps at idle and 220amps max. if the alt. rpms reach 6000 not the engine. with the power pulleys on both the crank and alt., these figures will be lower- probably around 140-160 at speed and should keep the charge good at idle even with highbeams and a/c going.It gets hot in cal even at night.
As for this Kj ********, I'm not much for words- a usually stay calm and keep my mouth shut while I kick the fu(k out of someone with a mouth like you. Too bad you don't live nextdoor.
P.s I'll gladly e-mail you my address if you would like to come over and play
Old Jul 11, 2002 | 06:49 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Well for someone is 35 years old, you sure act like a 12 year old.
Send me an email anytime you want.
I don't have my info all blocked off, like I'm tring to hide from someone. The paranoia of the Internet, your such a ***....
P.S. And I'm not saying I'm not acting like a 12 year old, But I'm only 21 one, so just flip it around.
Oh by the way, AFrikinGoodTime,
Old Jul 11, 2002 | 07:14 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
fun is fun,& flaming is flaming, but don't drag Ponch into this :nono:
Old Jul 13, 2002 | 11:09 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Guess you didn't what email me...
89GTAOz
May 16, 2020 09:31 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
evilstuie
Apr 14, 2016 08:52 PM
Navy8125
Aug 22, 2015 07:13 PM
Dialed_In
Aug 20, 2015 01:45 PM
