2.8 Throttle Body
Old Dec 3, 2002 | 08:32 AM
A4STARGEN's Avatar
2.8 Throttle Body
What size in (mm is our factory throttle bodys? I've heard 52 mm. Is this correct?
Old Dec 3, 2002 | 10:16 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I thought it was 48mm, and the feiro, non-interchangable is 52.
Old Dec 3, 2002 | 01:03 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
48mm? Wow..that kinda sucks.. Although even with a bigger one it probably won't help much more considering the plenum and heads....
Old Dec 3, 2002 | 11:37 PM
GreekSS350's Avatar
im not sure, i thought the v6 was 48 and the fiero was interchangable, ive got a 350 now, its got dual 42 mm throttle, but my buddy and i have been looking all over for junkyards with good fieros cuz he heard they are interchangable on the v6
Old Dec 4, 2002 | 02:58 PM
Nixon1's Avatar
I think the V-6 fieros have something funny with the throttle linkage, like it's on the opposite side or something weird that makes the throttle bodies non-interchangeable as Dale said..
Old Dec 4, 2002 | 05:06 PM
Shadey_MF's Avatar
Greekss350: What about mpfi celebrity euro-sports;
My linkage was so worn i couldn't set the tps. I found one on a celebrity that had the same part number on it as my 87 firebird.
It also had the same mat, maf, iac and tps. That celebrity was a gift from ***, i needed all those parts. everyone one wants to hose you as soon as you say "I need a xxxx for a Firebird".
thought i'd throw that in here if it's any use
Old Dec 4, 2002 | 11:17 PM
AFreaknGoodTme's Avatar
I own a 62mm Throttle body, I'm having extensive welding and porting being done to the plenium and intake manifold to match. Here's a link to them, don't know if you can still purchase one, I believe they have stopped making them-
http://www3.sympatico.ca/fjpeters/throttlebodies.htm
Old Dec 5, 2002 | 09:55 PM
camaro89dude's Avatar
Hey all you swap guys, it says they're making one for the 3.4!!
Old Dec 6, 2002 | 06:58 AM
Dale's Avatar
Engine: 350 S-TPI
I know, im on it already
However, that tb for the 3.4 is being made as a direct bolt up to the 3.4l intake, which is diff then the 2.8/3.1 intake, as so is the TB totally different
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
