View Poll Results: What cap and rotor do you like to use ?
Accel
20.00%
Blue streak
10.00%
Borg Warner
10.00%
Ac Delco (plain stocker )
30.00%
Other brand
30.00%
Voters: 20. You may not vote on this poll
Been alot of chat lately , and Im curious .
Old Jan 17, 2003 | 09:25 AM
WaynesRS's Avatar
Been alot of chat lately about "get a brass cap and rotor " Well, I'd like to see what everyone is buying on here !
Old Jan 17, 2003 | 09:55 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
On my 85 -- I buy the Conrad cap and rotor kit at AutoZone for about $20. I have heard that Conrad is the "budget division" of MSD but I'm not sure. Anyways, the cap and rotor do have brass inserts and seem to be of good quality.
83 -- Had an Accel on there until summer. The car needed an interim tune up so I replace the o2 sensor and the ignition module died. So went to AutoZone and traded it in. While removing it, I saw A LOT of carbon on the Accell stuff. Needing a quick cheap fix, I grabbed a Wells cap and rotor (no Conrad available), and threw on an older set of wires from the GTO. Been driving it that way since.
86 -- Cap that was on the car had a large crack so I threw on a Wells replacement. Car is not tagged (yet). After a few thousand miles, I might change it.
Old Jan 17, 2003 | 10:00 AM
WaynesRS's Avatar
I knew I was forgetting a brand , WELLS !!!! How can I forget when I have one on my car now ??? I had a bluestreak , but had to take it off to check it and had to tear it to pieces getting it off because one of the screws holding it down was stripped ! So I put an extra WELLS tha was still in good shape back on !
Old Jan 17, 2003 | 10:22 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Not sure of brand, came from orileys. Its red )
I think when I rebuild distrib, I will go with accell, or try and get that red kind again.
Old Jan 17, 2003 | 12:43 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I bought the Blue Streak because it was one of my only choices at the local parts stores, and it was the only blue one...I wanted blue.... Works fine for me! But it's only been on for a few months...
Old Jan 17, 2003 | 04:48 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I feel the same way, but i dont care much what brand it is, long as it has brass parts.
Old Jan 17, 2003 | 08:42 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Delco for me..........mostly because I can get Delco parts cheaper than others, but also because I regularly see aftermarket parts that flat out SUCK. However, Delco Durastop brake pads were the worst pieces of $hit I ever put on my car. Threw some $30 Raybestos' on there and no more "squeaky-squeaky".
Old Jan 17, 2003 | 09:07 PM
WaynesRS's Avatar
to bad delco does not make a brass cap huh ?
Old Jan 17, 2003 | 10:02 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'll say; I could've used an AC/Delco brass cap after http://www.geocities.com/tomp_3rdgen/burnt-cap.html happened! Right now I'm back on Accel; wanted to try the Borg Warner one but none of the local parts monkies had any in stock, so I just got another Accel cap/rotor kit from Summit.
Old Jan 20, 2003 | 09:18 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Brass
I really don't look for a brand name, but I do look for the brass parts, I've had much better luck with them... they seem a bit more durable to me.
Old Jan 21, 2003 | 04:13 PM
WaynesRS's Avatar
I remember that Tom !it's still hard to belive your car was running !!!
Old Jan 21, 2003 | 08:10 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
no matter which brand you get, this will make you feel better about your purchase:
95 Blazer distributor cap w/wires coming out the sides (cap-a-dapt style) $25 for Wells.
Rotor for said cap $10 Wells.
I've replaced the rotor & took a dremel w/wire brush to the cap. makes getting parts for the bird not so "painful"
Old Jan 21, 2003 | 08:23 PM
dsaint1347's Avatar
I have the Conrads right now anw they are pretty good.
InfernalVortex
Apr 20, 2021 11:31 AM
bjpotter
Oct 4, 2015 07:48 PM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Marc Brown
Sep 28, 2015 01:40 PM
