How hard is a timing chain to install?
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
What is the procedure to install a new timing chain? mine has 220,000 miles on it and i just read a post and the person said there engine was going clanky clanky clanky and thats exactly what mine is doing. My work sells a dynagear with top and bottom gear and chain for 15.00 how hard is it to change the gears and put the chain on?
Car: check
Engine: check
Transmission: check
Re: How hard is a timing chain to install?
This is not something that I would ever again attempt. Best thing to do is to pay someone else to do it. That way it's their hand that gets removed!
RBob., typing with one hand and two fingers.
Well hell if im gonna loose a hand il go for it then i wont have to work and just collect social security and disability
Car: check
Engine: check
Transmission: check
.Basically speaking the front of the engine needs to be torn down. Remove water pump, dampener, then timing chain cover. R&R chain/sprockets and reassemble.
This isn't a job that is easy to list out on a text forum. A search _should_ reveal some additional information.
RBob.
Want Help?
I have to go back in & redo mine as I forgot to install a new tensioner & also forgot to do the balancer snout sleeve!
$15!!!
LUCKY I PAID $30 for same brand!
Bring a balancer remover and a tensioner & a snout sleeve & new water pump for two!
I want to install a new water pump!
Don't forget gasket kits from Felpro!
PS Rememebr this part wil swap over to the new 3.4 block ya install soon!
You get the springs in!?
Missed ya at other house.
I ripped out some cabinets today.
Soon I remove linoleum floor & wanescoating in breakfast nook. Monday. Maybe mow lawn, too.
Sunday I sand new Firebird nose in Torrance!
$15!!!
What is the snout sleeve??? The gasket kit at my work is 15.00 with the snout sleeve. I should have the new springs tuesday and will be installing them wedensday then i get to go and do the front springs since the old ones have the spacers in them and they are origonal and rusted beyond belif. Karl where can i dispose of my old block??
Couple of choices!
Want money?
Bring to a scrap metal dealer
Want it gone?
Bring to Pick Your Part & drop off!
Tell them you forgot core paperwork!
Want it gone quicker?
Bring to local side of road or find a dumpster at a garage!
STRIP ALL PARTS OUTTA IT! Worth money!
Balancer REPAIR SLEEVE KIT snout sleeve is the item that's made by FelPro & Pioneer
I'll be back at other house on Monday
See you then?
Remember no cell phone for me!
Want money?
Want it gone?
See you then?
Ill probly be out there wedensday i got a wicked chest cold right now. I dont think any parts from the old enigne are worth anything except the heads. and tranny
heres the hardest parts, and problems you might run into...
taking harmonic balancer off....get special puller, still a pain, (puller i rented didnt have right size screws to fit)
putting it back on! (no one locally has install tool) block of wood and hammer was a pain
loosening screws on pulleys without the crank turning....a real pain...just use screw drivers/prybars/whatever....to hold a pully from moving.
be careful not to strip the first threads for the center bolt of damper/crank/pulley....i think i did with the damper puller!! took me darn near 30 minutes to get the bolt back in straight.
**use a straight edge to make sure you line up the timing marks on the gears.......true, probably not neccesary, however, i "thought" i might have put mine in wrong, (i didnt) but the peace of mind with being 100% sure would be worth it to check before you put it all back together.
***the biggest obstacle for me....TOOLS! who the heck put all those huge torx bits on my water pump??...needless to say, i spent way too much time because of trips to the parts store.
good luck
good luck
I allready have the harmonic balancer puller mine to keep
dosent sound too hard just how do i take the old gears off and put the new gears on and get the marks right and the chain on correctly?
dosent sound too hard just how do i take the old gears off and put the new gears on and get the marks right and the chain on correctly? One of the most fun tips I ever used!
I have a sharp metal chissel.
I HIT the chissel on the bottom crank gear at the key way.
Two wacks of 5 pound sledge hammer, the gear cracked open!
ALWAYS KEEP EVERYTHING LINED UP DOT TO DOT
I also have that star socket.
Other tip BRING AN OLD LIFTER from the Pontiac 350 engine.
Place that on center of balancer to prevent the bolt goof up.
Look for search for my timing chain replacement tips, after you get that girls image outta your mind!
PS CHECK YOUR BALANCER NOW!
YOU MAY need new one due to your milage.
It may be coming apart.
My 211,500 Blazer one? Came apart in two pieces when I removed it! I pulled outter ring off by hand! remainder of that Blazer balancer fought me to no end!
I STRONGLY suggest ya grab good one before I help ya.
When i did my waterpump my balancer looked in good shape i checked the sleeve and it wasent comming apart. if they make a liquid filled one i might go and buy one of those.
You may not be able to tell until you have it in your hands if it's history.
NO need for fancy in this engine.
Buy the sleeve.
It's $4 for me & I need to install it on mine on the Firebird. Along with new tensioner & new waterpump.
Pissed I gotta go back in (timing chain area) but then I'll not have to do it again for about 100,000 miles.
That's fine by me.
Buy the sleeve.
That's fine by me.
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I don't know what ked is trying to say, but very simply, you will need to drop the oil pan in order to get the timing chain cover off... be careful with this stuff or you'll spring an oil leak... It took me about 14 hours on the firebird which had a 305... about 4 hours could have been cut off from that if we had dropped the oil pan and it wouldn't have sprung a leak... DO NOT wedge screw drivers between the oil pan and block.
Other than that there's no real secrets, the haynes manual should be enough for you to get it apart and back together, just need to make sure the timing marks are right on... for obvious reasons.
Replace all gaskets removed and use RTV everywhere and last but not least don't get impatient, seal everything right the first time and let it sit as long as it's supposed to before driving.
I am referring to the fancy balancer Fast RS wants to buy. There is no need for a fancy balancer. Stock works perfect. Especailly when it's in good shape.
Incorrect.
The timing chain cover is separted from the engine block.
Oil pan remains on engine. Oil pan front lip is exposed upon timing chain removal.
Incorrect.
Car: check
Engine: check
Transmission: check
Originally posted by squirrelybird
i second that KED...i did NOT drop the oil pan.
p.s. i know tomp said his had two small screws through oil pan lip and timing cover. mine (91) did not. so just check.
Others, like yourself, have posted that their engine did not have them. Seems to be a. . . just check for them if the cover doesn't seem to want to come off. . .
Other then that, no, the pan does not come off.
Oh, the torx thing too, my '92 water pump has all hex head bolts, no torx, whereas others have torx. . .
RBob.
And what is it about this thread that keeps me wanting to re-visit??
My 1985 Firebird has two 10mm fine threaded bolts from oil pan to front t. chain lip also.
So does my 85 Blazer.
I hear different with some so........
PS MAYBE some others had their removed by those "GOOD" mechaincs!
The 3.4 motors do not have those two bolts thru pan to t chain.
3.4 motors use a flat pan.
I swap the 3.4 stuff & reuse my older 2.8 style everything on the 2.8->3.4 swap boogie!
2.8 has the exposed lip which also exposes to inside oil pan.
