Code 43 everytime I go thru water
Old Apr 12, 2003 | 04:14 PM
dsaint1347's Avatar
This is a weird one, I change both the knock sensor and knock sensor wire last year with no problems, but when it rains hard and I go over a huge puddle I get a code 43. Is it possible the wire is just shorting out or can the knock sensor be defective. Also a mechanic worked on my car last summer and when the moron messed with my starter he pulled the wiring harness too close to the exhaust manifold causing a small fire, Most of the wires were shorted out but I fixed most of them .......I think. This summer I will change the harness.
Old Apr 12, 2003 | 05:41 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
It's probably the harness. When it gets wet, a drop of water might short it out against the manifold. Could very well be your problem.
Old Apr 12, 2003 | 05:57 PM
dsaint1347's Avatar
I am going to have fun changing the harness, I also lost the negative signal or ground to my fuel pump. I had to ground the wire coming from the fuel pump to make it run again.
Thanks again!
Old Apr 12, 2003 | 09:58 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I see you have discovered, just like I did, that most shops employ idiots! I will never again have a shop install a starter for me. They overcharged me big time, and used a rebuild job instead of a remanufacture. Yeah, it seized, with very little warning, in a parking lot 8 miles from home. On Christmas Eve. Talk about an expensive tow. $10 per mile.
I'd expect that that wiring harness would be the culprit.... That really sucks man..that'll probably be a nice bit of a pain in the ***. Good luck on that.....
Old Apr 12, 2003 | 10:05 PM
dsaint1347's Avatar
Thanks, I am used to wiring. I work with wires all day at work.
Old Apr 13, 2003 | 12:47 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
If I where you I would go to a junk and get the whole harness in that area OR go to GM and buy the splice in harness that they have. I bought the pig tail for the knock sensor when mine broke from being old.
Old Apr 14, 2003 | 01:17 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I did the same thing for my dad's old '87 a-body. Knock sensor code kept coming up, but the knock sensor was giving off an okay value, so I replaced the knock sensor connector, thinking it was bad. (Turned out to be a bad ECM, though.) The connector is also spec'd for the a/c system and for your BRAKE warning light (on your brake's prop valve, right below the master cylinder) if you can't find a connector labeled "knock sensor" in the parts department.
Old Apr 14, 2003 | 08:19 PM
dsaint1347's Avatar
Thanks, when I had the small fire it melted about 12 cables and I soldered most of them. The knock sensor cable was replaced. My guess is that one or more wires were toasted beyond repair so I'll just swap the whole harness from firewall to te front grill. Should be fun.
92firebirdguy
Sep 1, 2016 07:53 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
st.evel07
Sep 19, 2015 09:24 PM
84redta
Sep 19, 2015 09:58 AM
gta892000
Sep 16, 2015 12:37 AM
