89 RS misses while driving and idiling
Old Apr 13, 2003 | 05:48 PM
92Z28CamaroRulz's Avatar
Did a tune up: Cap, Rotor, Plugs and Wires and got a O2 Sensor, My uncle's 89 RS with a 2.8 and a 5 spd is missing like a pig, When we were driving, It kinda smelled like gas and you can feel the miss, It's been sitting for awhile and really hasn't been driven enough to get the kinks out, It's been sitting for about a year and I drove it about 5-10 miles within the last year. Thanks
Rob
Old Apr 13, 2003 | 08:31 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
the best i can tell u would be to check the compression. There could be a bad valve or even worst a bad piston ring. I had the same problem with my 84. Checked the compression and the #1 cylinder wasn't giving anything. Ending up being the piston ring.
A guage to check the compression does not cost all that much. U have to check all the cylinders. If all of compressions are pretty close ( around the same # ) u have no problems. But if one is significantly off, well u have a challenge ahead of u
Old Apr 13, 2003 | 09:09 PM
That's not the problem though man, The car still picks up speed like crazy and it seems to run and idle fine, No ticks, No knocks no nothing. Is there anything else it could be?
Old Apr 13, 2003 | 10:12 PM
KED85's Avatar
Weak EGR Valve.
Factory original coil?
AND crossed wires somewhere!
PERHAPS a burnt plug wire by accident?
Old Apr 13, 2003 | 10:18 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
do you have a hunting idle............hook up a vacuum gauge and see what your vacuum looks like
Old Apr 14, 2003 | 11:42 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Mine's doing this now - mine is because it's so damned hard to get those plug wires ALL the way on, and work on it, with all that frigging AIR and EGR crap in the way. Guess what's getting removed this week?
Old Apr 14, 2003 | 01:11 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
If it's been sitting around awhile it might be stale gas. Try to fill up with some fresh stuff and drive it a while. Check your plug wires in the dark to see if any of them are leaking, new ignition coil may be in order and a new ignition module.
As for the gas smell..... hmmmmmm look under the hood by the fuel lines.
Does your tach needle twich when driving a constant speed, I would replace the pick up coil, common problem is it gets weak and doesn't pick up when to fire a cylinder.
Old Apr 14, 2003 | 08:51 PM
We now have gotten the miss out of it when idiling, Now it only does it when driving.
Old Apr 14, 2003 | 09:58 PM
What did you change to get it to do that much?
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Bryan F
Aug 18, 2015 02:28 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
