have to switch 84 V6 carb. to 87 efi
Old Jun 6, 2003 | 10:32 AM
CurtisW831's Avatar
I've run into a lil snag, I have to switch an 84 electically carburated V6 into EFI, the snag I've run into now is the timing cover. the 84 is a non-goodwrench engine and the 87 engine appears to have a goodwrench pan. are there any 87s that I can get a timing cover from or a place I can buy an aftermarket one. only reason I need to change the timing cover is because the water pump impeller channels run opposite of what I already have.
Old Jun 6, 2003 | 10:19 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
are your water pump runners like this, or reversed?
Old Jun 7, 2003 | 03:09 PM
CurtisW831's Avatar
Right now they run like in the picture, I need them to run opposite of that. I need a timing cover where the front 2 bolts of the oil pan go into the timing cover. I'd send pictures, but my scanner doesn't work.
Old Jun 7, 2003 | 08:24 PM
Engine: 5.7 / 7.4
well, the 3.4 has the runners opposite as the pic, a mirror image, but the front two bolts of the erl pan go into the block, not timing cover.
Old Jun 7, 2003 | 08:38 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wacky. Hey why not buy a reman water pump for an '84?
I thought they all used the same pumps, 80 (Citation) to '89. Oops.
Old Jun 7, 2003 | 08:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh hell nevermind, '87-'92 must have different rotation due to the serpentine belt system, right?
Old Jun 7, 2003 | 09:06 PM
Engine: 5.7 / 7.4
well, on the 85, looking at the engine from the front back, waterpump rotated clockwise. On the stock 3.4 engines, it rotates counter clockwise, as the belt runs inderneath the pulley.
Hope this doesn't confuse more
Old Jun 7, 2003 | 09:53 PM
KED85's Avatar
You seek a timing chain cover for the 1985 & earlier 60* engines.
You can find them on S-Series & the F Bodies
Those t covers have the two bolts on bottom of cover that ya seek.
IF ya score a used one be sure to check water passages for water aging damage.
Old Jun 7, 2003 | 10:04 PM
Engine: 5.7 / 7.4
of course this comes about a week after I get rid of the 2.8 block w/timing cover on it
Old Jun 8, 2003 | 10:10 AM
CurtisW831's Avatar
so does this mean that the 85 TBI have a serpentine belt system and the same block as an 84?
Old Jun 8, 2003 | 10:12 AM
CurtisW831's Avatar
sorry about any misspellings or poor grammar. this car is my daily driver and I've been stuck borrowing my grandmother's toyota station wagon.
Old Jun 8, 2003 | 10:34 AM
KED85's Avatar
NO such thing.
Here's a pic of a 1985 S Series with a 3.4.
Yeah, It's designed to look exactly like it was as a 1985 S-series 2.8, for CA smog purposes.
Notice the carb.
1985 F body is the MPFI, a first year, PVC hose routing one year design.
I have a spare t cover, yet water passage is aged, which is why it's a spare or decoration, now!
Old Jun 8, 2003 | 12:32 PM
CurtisW831's Avatar
ok, what exactly do I need to take the timing cover off of for it to have the 2 holes on the bottom and have water channels opposite of what's in the first picture?
Old Jun 8, 2003 | 01:04 PM
CurtisW831's Avatar
basically, is there an 85 with a serpentine system? when was TBI used? my 84 didn't have it. and did the TBIs use a serpentine system? If so, did they have the same block as the 84?
Old Jun 8, 2003 | 06:51 PM
KED85's Avatar
There was NEVER a TBI F Body.
There IS S-Series 1986-to sometime in 90's, 60* (2.8 I believe) with a TBI.
I am unable to offer an answer on the serpintine belt set up.
Old Jun 8, 2003 | 08:05 PM
CurtisW831's Avatar
I've seen 85s and 86s with 2.8 and TBI. Anyway, doing some rudimentary digging through an autozone computer revealed there's only 1 timing cover gasket offered for 85 which is the same pn as in 84, and it also said there were 85s with v belts and with serpentine belts so I guess I have my work cut out for me. If I can ever get my scanner working right I'll go more into the TBI thing, but here in FL there are many and many people have problems with them.
Old Jun 16, 2003 | 07:11 PM
CurtisW831's Avatar
ok, a guy at a junkyard here in orlando helped me out. turns out as long as I change the oil pan with the timing cover they'll both fit perfectly and as long as it's 87 and older. if it was 88 and newer then I'd need some sort of electric oil pump system. I still thank you for attempting to help.
Old Jun 16, 2003 | 08:26 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
86-93 2.8l S-series TBI engines.
Have intake, TB, aircleaner, computer on ebay right now
Old Jun 17, 2003 | 04:27 PM
CurtisW831's Avatar
thanks, but I have everything I need now, including a nice lil surprise in my cheap shell I bought. apparently the worn out engine in the 87 was bored 40 over and whatnot, so eventually I'll rebuild it and probably add turbo so I can kick pcbootleger's ***.
matthew911
Aug 12, 2015 09:38 AM
twells
Jun 27, 2001 01:24 PM
speedlvr
Carburetors
May 9, 2001 09:35 PM
PPonU4Me
Feb 4, 2001 03:20 AM
MIKES 88GTA
Sep 24, 2000 10:04 AM
