3.1 to 3.4
Old Jul 1, 2003 | 07:53 PM
6cyl92CamaroRS's Avatar
Car: 92 Camaro RS
Engine: 3.1 L
3.1 to 3.4
I've been searching now for quite awhile and havent found this question yet.
I have a 3.1 right now with only 60k on it the cars been wrecked for a long time and just now getting fixed and runs nice and i was wondering besides the CAI and exhaust and stuff what can i put inside the engine such as cam and roller arms or whatever they are that will be a real nice upgrade to the 3.1 but whenever this 3.1 wears out (which could be sooner than usual due to sitting for so long) that i can swap in the 3.4 and it still be an upgrade to that thanks.
Mitch
Old Jul 1, 2003 | 07:54 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
pretty much........................everything.
Old Jul 1, 2003 | 08:01 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Yep... exhaust upgrades and head work would go a loooong way!
Old Jul 1, 2003 | 08:40 PM
F585's Avatar
Your 3.1 will be fine you won't believe how long my car has been sitting check my sig for mods
Old Jul 1, 2003 | 08:50 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Every thing can be swapped. I just wouldn't invest in any head work. The 3.4l heads are better if you see a 3.4l swap in the future.
Old Jul 1, 2003 | 08:57 PM
F585's Avatar
How are the heads from the 3.4 better then the 2.8/3.1? What are the specs?
Old Jul 1, 2003 | 09:12 PM
Doward's Avatar
Everyone says the 3.4s are better. I can't find a single pic of a 2.8/3.1/3.4 side by side.
Old Jul 2, 2003 | 06:39 PM
Car: 92 Camaro RS
Engine: 3.1 L
Well i got another question i dont have the car yet its still in the show whenever the f***ers put the front end on it i was planning on putting 1.6 rocker arms on it along with a new cam, intake and exhaust do you think it would be safe to get this stuff now so when i get the thing and im all excited about fixing it up i dont have to wait or would it be good idea to wait and if so what do you guys think would be good rocker arms to get and new cam and im aware ill need a new valve covers for it and also before i put a new cam and rocker arms in it should i do anything before that besdie the intake and exhaust? im looking for exacts cause i really dont know where to look for so long i was planning on swaping in a 350 then relized hey i dont have any money so i would love the help
Old Jul 2, 2003 | 06:59 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
After I totalled my car, it sat for a month while I bought a parts car, stripped both to a frame, and saved up enough cash to have a shop do the frame swap. When I started it back up again, not only did I put a huge cloud of smoke over the neighborhood, but my valve seals started leaking. I think sitting for so long dried them up; now I get that little blue puff of smoke out of the tailpipes from the exhaust. Also, it wouldn't start right after I rebuilt the car. I thought I botched the wiring up. My dad suggested we try putting new gas in- I had wrecked it with the needle almost on "E". A few 3-gallon cans of 93 octane later and it started up.
Squirt some oil into the spark plug holes and spin the engine clockwise manually with the center bolt on the crank pulley. Then remove your coil wire and crank the engine a bit to build up oil pressure in the engine to lube things up a bit.
If you do the rockers, the valve seals will be "right there" waiting for you... you'd just need compressed air and an on-the-car valvespring compressor to change them. There's also a "thin rope" method for keeping the valves from falling into the cylinders... HAH! I love the search feature on thirdgen.org!! Here's the message I wrote up about the "thin rope method": https://www.thirdgen.org/techbb2/sho...144#post952352
So I think the only problems are (A) gas might be dead, (B) valve seals might start leaking a bit, (C) all the oil is definately out of the passageways and just sitting in the pan.
Old Jul 3, 2003 | 06:06 PM
Car: 92 Camaro RS
Engine: 3.1 L
I'm figuring ill just let the guys that said they would put the front end get the engine going too and ill go from there but im just wondering if i put new cams and rocker arms in should i do anything else under there i got 900 dollars i want to put my car into right away and then have money later and i got the exhaust and intake coming along with cam and rocker arms but since im going to be putting the cams in what other parts would be good to be put in thanks
Mitch
Elephantismo
Feb 13, 2019 12:51 AM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
92projectcamaro
Sep 29, 2015 07:07 PM
cking99
Sep 22, 2015 11:33 AM
