High-flow cat brand
Old Jul 25, 2003 | 02:17 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
High-flow cat brand
What brands have a bolt-on high-flow cat for the 2.8? Is it possible that they are listed under another engine, like the 3.1, or the 3.4? Thanks.
Old Jul 25, 2003 | 04:22 PM
socialdeviant's Avatar
catco 2 1/4 universal. 60 bucks...
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
We use the v8 cat.
Specifically:
2.5" slip-fit inlet
2.5" ball-flange outlet
Look up the v8 f-body catco cat using those above specs from http://www.summitracing.com and you'll see the application guide also lists our 2.8/3.1's.
Old Jul 25, 2003 | 04:27 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
2 1/4 universal? Not on my car, nor should it go on anyone else's. Factory cat is 2.5 inch inlet. Why would you drop down a level, and pay someone to weld it in? Go for the 2.5"I described above, CTO-4115, it bolts right in. If you're getting a high-flow cat you might as well get the correct pipe size.
Originally posted by TomP in <a href="https://www.thirdgen.org/techbb2/showthread.php?s=&threadid=62061#post367755" target="newwin">this old message</a>
Your CatCo cat # is part #CTO-4115. That was found thru Summit's site, http://www.summitracing.com . I did a "Manufacturer Search", and on the top of the search screen, I told it department = "Exhaust", section = "catalytic convertors", manufacturer = "catco". A list popped up. I chose our setup, which is a 2.5" inlet, and 2.5" flanged ball outlet. A box popped up- and the cat looks just like my current one (made by PFP, not carried by Summit anymore). I clicked on applications, and there it was, standing out at me- 82-92 Camaro 2.8/3.1 ! If the pic & and description (flanged ball out) is right, this not only the cat for your car, but it's a direct bolt-in (no welding required)!
Oh; the cat on my car is the one Karl mentioned; made by PFP. Part # is buried somewhere at home- I put that on back in 1996. If I come across it this weekend, I'll put it up.
Old Jul 25, 2003 | 05:02 PM
TomP
Unfortunately the parts store that I deal with (my brother works there) doesn't carry Catco. They have Dynomax, Magnaflow, and possibly Flowmaster. So should I get him to look up a high-flow for an '86 (same year as my car) 305 or 350? This will be what I want?
Thanks,
Jason
Old Jul 25, 2003 | 05:53 PM
91Z28-350's Avatar
Dynomax is expensive, IIRC. Magnaflow is the CarSound cat, which is well known. I'd go with the Magnaflow, or whatever is cheapest between Dynomax and Magnaflow.
My car uses the 2.25" cats...but I have 2 of them.
Old Jul 25, 2003 | 07:06 PM
But will the Dynomax or Magnaflow one that I want be listed as an '86 305, or 350?
Old Jul 25, 2003 | 09:16 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Stock is 2.5" in& out????? The one I got @ AZ looks like a 2.25 in & 2.5 out, as the ballend fits perfectly to the dynomax I-pipe.
Old Jul 26, 2003 | 12:07 AM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
I am running a Dynomax converter. I ordered mine from Jegs. It is a 3 way converter and fits 83-89 Camaros. The part number is 028915735. It cost $89.99 before shipping.
Old Jul 26, 2003 | 01:00 AM
If you go to http://www.discountconverter.com/con...earch_make.cfm and put in the make and year, you'll come up with the converter for the camaro. This page actually says (if you click on the part number) that it fits the 2.8. Thanks to CC_HotRod for the part # (15735 is the dynomax product number), and always to everyone for the input.
Old Jul 28, 2003 | 02:19 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wow... freakin' weird... I coulda swore it was a 2.5" inlet. Okay, I'll measure mine when I get home.
Old Jul 28, 2015 | 03:28 AM
nickespo's Avatar
Re: High-flow cat brand
So i have an 86 2.8. I just baught pacesetters and i believe the outlet is 2 1/4 but the dynomax exhaust i got is 2.5....what do i do to make this work? This is my first project and im very new at this so any tips besides swapping my 2.8 for a 350 or taking it to an exhaust shop would be great lol
Old Aug 3, 2015 | 08:07 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Necropost but I'll answer anyways...
Get a MagnaFlow 93441 and cut the inlet off. Call Summit and get a 2 1/4" to 3" OD adapter and put the adapter on in place of the inlet flare on the cat. Measure the outlet of the crossover pipe first. I think it's 2 1/4" OD but I couldn't swear to it.
Old Aug 3, 2015 | 08:54 PM
nickespo's Avatar
Woah sorry about that. I didnt even see how old these messages were. Im a new third gen owner and thought this site might be able to help me out. Lol i feel retarded now. Thank you for getting back to me anyway.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
mud runner
Nov 2, 2015 07:30 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
Stryker412
Sep 20, 2015 06:59 PM
Camaro_383
Sep 11, 2015 11:28 PM
