broken part what is it called?
Old Aug 25, 2003 | 04:23 PM
syknesss's Avatar
Car: 91 Firebird
the part where the bolt goes on it gone and so are the bushings whats this called exactly so i can buy a new one? btw its in the rear hooked to the strut brace i guess? and its a 91 rs 3.1
Old Aug 25, 2003 | 05:08 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
rear swaybar endlinks.
Old Aug 26, 2003 | 12:21 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, but while you have the chance, don't just fix the problem- improve your suspension while you're in there!
Call up Summit Racing at 800-230-3030 and order part # ENS-9-8117R for $13. That's a polyurethane end link kit, and it won't mush out like rubber will under tight turns. If you get ambitious, order two of them, and change your front sway bar's end links, too. Chances are 99% that you'll have to cut your old links in order to get them off.
Some local parts stores carry polyurethane end links too, but they usually charge $20 for a set. You want end links with a "two and five-eighths inch sleeve length".
Old Aug 28, 2003 | 07:59 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
pepboys sells polyurathane endlink for 5 dollars each. no different then a more expensive endlink w/ a big name manufacture on the box. polyurathane is polyurathane.
Old Aug 28, 2003 | 08:46 PM
syknesss's Avatar
Car: 91 Firebird
im gone with the pepboys ones
Old Aug 28, 2003 | 11:13 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
$5 each? Wow... 5 or 6 years ago, they wanted $20 for those no-name jobs. I guess I'm showing my age (just turned 27 on Thursday... yikes)
Old Aug 29, 2003 | 02:12 PM
syknesss's Avatar
Car: 91 Firebird
$7.99 each im gonna pick em up tongiht
Old Aug 29, 2003 | 05:18 PM
dsaint1347's Avatar
How would you know what size endlinks to get?
Old Aug 29, 2003 | 08:59 PM
TekViper's Avatar
Engine: 3.1L v6
weird, when i got them i could have sworn they were 4 dollars and change. the parts computer at the parts store will get u the right size links.
Old Aug 30, 2003 | 08:31 AM
dsaint1347's Avatar
My rear sway bars are not stock
Old Aug 30, 2003 | 03:34 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That's how you know. Parts store computers be damned! (Well, not the computers so much as the operators...)
Old Aug 30, 2003 | 06:05 PM
Anjiru's Avatar
changing a little peice of rubber for some Polyurathan is that much better??? I mean is the difference noticable?
Old Aug 30, 2003 | 06:28 PM
TekViper's Avatar
Engine: 3.1L v6
i personaly think its not so much the difference in ride quality, more of how long they last. the poly bushings will outlast the rubber ones. the poly also do tighten the rear end a bit but you may or may not notice it.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
