4th gen shifter in 3rd gen?
Old Oct 29, 2003 | 09:29 PM
F-Bodeee's Avatar
Car: 1991 Pontiac Trans Am
Transmission: Borg Warner T-5
To all you thirdgen 5 speeds (the few there are).....has anybody ever put a 4th gen shifter into a 3rd gen? I know it's possible....but has anyone done it? My friend has one he isn't using and i'm gonna put it in mine. It's gotta be shorter than the stock 3rd gen shifter.
Old Oct 29, 2003 | 09:35 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
You saying it has a shorter shift pattern???
I got a T5.
Matt
Old Oct 30, 2003 | 09:23 AM
jeremy178's Avatar
Car: '89 Camaro RS
yeah, I think they are about 1" shorter or so. But I kinda doubt they'll bolt up the same, try it and see. good luck
Old Oct 30, 2003 | 11:12 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
They do bolt up the same, infact I think they are the exact same shifter.
Old Oct 30, 2003 | 01:05 PM
F-Bodeee's Avatar
i know they bolt up the same. When i drove my friend's 94 5 speed the shifts were much shorter than in my car (89 5 speed). So, this weekend i'll see and i'll let u guys know.
Old Oct 30, 2003 | 01:08 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Let us know. Check the size and shape to. Maybe I can just knock a inch off mine and expoxy the ball back on. Don't think I wont do it.
Matt
Old Oct 30, 2003 | 01:19 PM
F-Bodeee's Avatar
will do
Old Oct 30, 2003 | 09:41 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Why not just snag one from a salvage yard? A factory short throw shifter.
Old Oct 30, 2003 | 09:55 PM
F-Bodeee's Avatar
wut u mean factory short throw shifter?
Old Nov 9, 2003 | 02:24 PM
F-Bodeee's Avatar
well, i did it this weekend and in fact, it is shorter......not in height....but the shifts are a little shorter. I guess it's now a factory short throw shifter. For free, it's not a bad deal....however i still want a pro 5.0 shifter
Old Nov 22, 2003 | 01:49 AM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
yes
i want one of those to, my bud has a 95 formula with one he cant speak highly enough of it, so precise he says, arg i wants one!
Old Nov 22, 2003 | 05:48 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
who has the best deal on a pro 5.0 shifter???
Old Nov 22, 2003 | 05:52 PM
F-Bodeee's Avatar
only place i've seen them is www.pro50.com
Old Nov 22, 2003 | 11:34 PM
Engine: 350ci
look harder
http://www.hawksthirdgenparts.com/in...l?v=1&pid=8984
http://www.thirdgenresource.com/inc/...l?v=1&pid=1219
http://www.fbodymotorsports.com/inc/pdetail?v=1&pid=224
http://www.pro50shifters.itctv.com/d...&A=E&PKV=P3050|0
theres three more + the company site
...look on ebay too just incase someone sells them there, used or other wise
http://www.fasttoys.net/8292fbodyframes.html
scroll down to it, the cheapest ive seen 181$
Old Nov 24, 2003 | 04:39 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I got a good shifter that came with my trans but it was cut of right at the bottom lock nut. I was in the shed last night playing with it griped in the vise thinking I could experiment and make different handles.
From the pico f the 5.0 shifter it look as hey are much straighter, shorter.
stock one has a lazy bend toward the driver about 3 inches up. and these seam to lean to wards the driver a tad but are straight and short.
Course I could use it to make a 50's retro shifter that needs a hole cut in the roof just to shift it.
Old Nov 24, 2003 | 05:40 PM
Teenfixing88RS's Avatar
Car: 1988 Camaro RS
Matt
Tell me he didn't say that....
Old Nov 26, 2003 | 09:59 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I figure the boot with cover most to half of the chrome piece. This was a shifter I got with my trans, it had been cut clean off where the stock two piece one went together.
Still has / uses the stock bend in the bar towards the drive and I added on about a piece of 4 inch pipe. Cutoff a piece of chrome pipe to cover the weld and finish it off clean. The handle is a side grip for a drill I never used. Cut the bolt off the top flat and ever.
I had it in the vise jerking it around through the gears. Feels solid.
Of course it could end up working like crap, but I had some free time and threw something together.
But it feels real comfy and solid.
Old Nov 28, 2003 | 09:32 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
OK so it ended up worse than it looks. I was using it back wards and that really matters. The bend goes towards the passenger seat cause the T5 is twisted to the left. So that screwed everything up right there and it was about 2 inches to short if I kept using the center console.
Ill hack if off and try again, this time with it mounted in the vise the right way around.
Old Nov 30, 2003 | 06:24 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I don't wanna muck up this thread with a bunck of pics but the new
G Money Special is over here
https://www.thirdgen.org/techbb2/sho...82#post1581982
Old Dec 1, 2003 | 07:29 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Ok how abou the short throw mustang T5 base
item=2446161014 $40
And the T56 short throw top piece
item=2445816022 $30
Drops the price to around $80-$90 for a new shifter.
the T5 base is the same it just has the never attachment points that could let you use any top piece.
Old Dec 1, 2003 | 07:36 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
item=2445516621
Pro 5.0 handle for $20
Old Dec 1, 2003 | 08:07 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Yeah, but you're still dealing with that rubbery 'feel'. Play with a stock shifter, then a good aftermarket shifter, and it's night and day.
For the extra $$, you also get positive stops (easily built, tho) but what about the 2-3 spring loaded shift assist?
Old Dec 1, 2003 | 03:47 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Head over to the trans section for the pics, but man did my retro shifter work out sweet as heck. Its actually a short throw shifter also. 1-2 is about half the distance as it was before.
Old Dec 10, 2003 | 02:16 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
OK, so I cut the money sign off and finished my pro 5.0 clone. it helped though using the funky shifter for a while. I got the shape and size right this time around.
3rd times a charm.
Course it still the stock base,
no shift stops but cheap cheap cheap.
Old Dec 10, 2003 | 05:38 PM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
Nice watch
Old Dec 10, 2003 | 05:50 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If budget will allow, I agree with Doward, go after market. My B&M is one of the best mods I've done. See sig.
JamesC
Old Dec 10, 2003 | 06:15 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
A B&M short throw has been on my list for a while. But they're so expensive. Maybe for my birthday...
edit: FYI the B&M short throw is listed on Summit for '83-2000 Camaro/Firebird T5. The Hurst Billet Plus shifter is the one I had my eye on.
Old Dec 10, 2003 | 10:27 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Originally posted by 9D1BURD
Nice watch
Thats my Bart Simpson "Cool your jets man" watch.
I need a reminder sometimes.
Warlocksirix
Sep 3, 2015 12:26 PM
neekolzun
Aug 24, 2015 04:59 PM
cam-mike
Aug 24, 2015 07:23 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
