lowering spring for V6 (pls help)
Old Jan 22, 2004 | 04:03 PM
joekickass's Avatar
Car: 1989 Firebird V6
Engine: 2.8
Transmission: auto
hello, I think it won't be a new subject, my dropzone spring is on the way, they are for v8, I think I can cut them to low my v6, is there any body have done that before ? how much should I cut?
thank a lot!
Joe
Old Jan 22, 2004 | 05:17 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
well, you shuld have just got the springs for the V6, they do make them. 200 and change.
as far as how much spring to cut off... I think the consenus was 1-1.5 coils. REMEMBER NO TOURCHES! ONLY CUT OFF WHEELS!
Old Jan 22, 2004 | 07:21 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
contact lt1guy, or redrarif, they installed v8 springs in a v6, then can let you know how much to cut off.
Old Jan 22, 2004 | 08:56 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
i have dropzone springs on mine, they only make them for v6 cars, none for the v8's. you wont have to cut them at all.
Old Jan 22, 2004 | 10:10 PM
LT1guy's Avatar
Car: 1987 Trans Am
Redraif's are Eibach Pro Kit springs, which they only make for a V8. We cut them 1/2 coil (never cut more than 1/2 coil at a time; its easy to remove and cut more, impossible to put it back!). Uncut, the V8 springs raised the front end HIGHER than it was with no engine or transmission!
Old Jan 22, 2004 | 10:19 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I just wonder.
Don't some springs have a tighter wind and the top then bottom? Which end would you cut from?
Just for reference.
Old Jan 22, 2004 | 11:05 PM
LT1guy's Avatar
Car: 1987 Trans Am
If I remember correctly, we cut from the bottom.
Old Jan 22, 2004 | 11:28 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
I would love to know where you got this information, as 1, making only springs for the much-ignored V6 seems silly, and two, I can find absolutely no reference to whether they were designed with the V6 or V8 in mind. Please, enlighten us.
Old Jan 23, 2004 | 08:28 AM
drdave88's Avatar
Engine: 6.0L
the info came straight from the sales rep who sold them to me over the phone. i was wondering the same thing as joe. he told me they dont make them for the v8's yet, only the v6 so i wouldnt have to cut or do any type of modification. theyve been in since july and my car looks and rides quite nicely.
Old Jan 23, 2004 | 08:48 AM
Dale's Avatar
Engine: 350 S-TPI
dave, do you have a side view?
Also, do the springs feel stiffer, how much of a drop, even bounce around the car, etc. Can you hook us up with more info. Your the only one I know with dropzones.
Old Jan 23, 2004 | 08:51 AM
drdave88's Avatar
Engine: 6.0L
i can get a sideview of it soon, up at school right now. it does have a bit stiffer ride w/ KYB shocks and struts. the bounce is even all the way around, just make sure you have the rest of the suspension fixed it seemed a bit harder at first in the back, but once everything settled, it evened out. the only problem i have now is whenever i raise the back end of it on a hoist or whatever, i have to make sure the springs are positioned correctly before setting it down.
the drop was about 1.5 inches total. the front end actually came up a half an inch b/c the old suspension was so wasted, lol.
Old Jan 23, 2004 | 04:27 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I got suspension techniques v-6 lowering springs they did help in handling but if i ever have to replace springs again i will go back to stock hight because all i do is scrape the bottom of my car. and i cant go over speed bumps.
Old Jan 23, 2004 | 09:02 PM
Dale's Avatar
Engine: 350 S-TPI
fast rs, you got pics of yours? Now that I "know" people that have both, I wanna see them side by side.
fast rs, wanna trade
Old Jan 23, 2004 | 10:28 PM
FAST RS's Avatar
I will probly be takin pics in the next few days. Gotta get it washed i havent really drivien my car in 2 months.
Old Jan 24, 2004 | 05:54 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
so with 1.5 inches of drop you are hitting things? damn, there is no justuce....
Old Jan 24, 2004 | 05:59 PM
FAST RS's Avatar
no i did a 1 inch drop. ill go take some pics right now they wotn be the best because my car is in the grague
Old Jan 24, 2004 | 06:16 PM
FAST RS's Avatar
I will take then next week i need to figue out how to lower the quality of the pics so i will take them next week. But i only did a 1 inch drop. Back springs are easy front springs i had someone do because they are a bitch to get out and put in
Old Jan 24, 2004 | 08:27 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
ftp://ftp3.ulead.com/pub/Trial/Ssaver/Ussp30to.exe
Ulead Smart Saver 3.0
It will shrink the files size, not the pic size. so you can go ahead and take a 1meg pic and shrink it to half it files size [ not the image size] file size.
I repeat that as people get confused and think I mean image size.
ie: 800k file into 400k file and it will look just as good.
Old Jan 24, 2004 | 08:53 PM
Dale's Avatar
Engine: 350 S-TPI
I'm surprised a 1" drop made you drag that much. My car currently sags about 5/8" an inch. I was wanting to do another .5-.625 more along with stiffer.
Old Jan 24, 2004 | 10:58 PM
84Berlinetta3rd's Avatar
Car: 84 Berlinetta
Engine: LC1 V6
Transmission: 5 Speed
I just put in drop springs and struts today. Before and after measurements, it dropped 1.25 inches. The springs are ST's $145 delivered. They have more metal then the stock ones did, yet shorter...Denny
PS - Anyone want a set of stock springs? Only 23,000 miles and 20 years old!
Old Jan 25, 2004 | 09:13 AM
Dale's Avatar
Engine: 350 S-TPI
ST's for 145 shipped WHERE, I can only find them for 210 plus shipping
Old Jan 25, 2004 | 05:04 PM
Car: 84 Berlinetta
Engine: LC1 V6
I just completed putting in the rear springs and shocks today. The car looks, rides, and handles GREAT!
WWW.SUSPENSIONMAX.COM
Denny
Old Jan 25, 2004 | 06:49 PM
Dale's Avatar
Engine: 350 S-TPI
Hum, that says 1.75", and you said it only dropped 1.25? I guess your car was sagging .50 already, or it needs to settle in some.
Have you drove it yet? Stiffer?
We need pictures!!!
Old Jan 27, 2004 | 07:08 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, same here (same springs, too). I thought "oh, an inch won't be that far" - bs, because I hit everything. The ride is great and the handling's great, but I didn't know I'd turn into one of those guys that swerves around raised manhole covers! Man am I glad that I didn't go for an even lower drop!
Old Jan 27, 2004 | 07:38 PM
Car: 84 Berlinetta
Engine: LC1 V6
Dale, they advertised 1.25-.75 and from reading lots of forums the best you can expect from the ST's is 1.25 drop. I do not swirve from anything and I do not bottom out, BUT remember the 84 Berlinetta was made higher for the ladies skirts! So my lowering is just getting it down to where you already are.
I have 26.25" front and 26.50" rear from the ground through the center of the tire to the top underside of the wheel well. Pretty even with a .25 drop rear to front.
Old Jan 27, 2004 | 07:58 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I have wondered about that through this whole thread. Stock ride hight is almost to low for me once you hit the inner city streets. I could even go for a lift in some places. I would say most of the blame is the hi semi volume that either crowns the middle of the lane 3 feet high or you get that wavy bumpy pot hole mix. most roads are a wild Dukes of Hazzard ride. You either do 20 mph and rock n roll over them or nail it do 50 and skip over most of them.
Them raised pothole covers suck.
Old Jan 27, 2004 | 08:39 PM
Dale's Avatar
Engine: 350 S-TPI
84, thanks for the dimensions, I will measure mine to try and get a good guess.
Can you tell me what size tires them dimensions are on? Or do from center of tire to fenderwell.
Old Jan 27, 2004 | 10:20 PM
Car: 84 Berlinetta
Engine: LC1 V6
14.75 Front / 15.00 Rear from center of tire cap to wheel well...Denny
Old Jan 30, 2004 | 05:37 AM
Car: 84 Berlinetta
Engine: LC1 V6
I have pics at this thread:
https://www.thirdgen.org/techbb2/sho...1&goto=newpost
Black88Z
Jan 17, 2012 12:21 AM
bensbaby
Brakes
Aug 10, 2011 07:46 AM
joekickass
May 20, 2005 09:34 PM
Jer82Z28
May 21, 2003 12:23 AM
