MOre wiring questions for y'all
Old Jan 24, 2004 | 08:41 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
That sliver relay/whatever it is that's located under the pass side dash, where you have to take off the bottom cover to see (no, not the ecm). What does it go to? Just want to make sure that I don't remove any needed wiring
Old Jan 25, 2004 | 08:50 AM
Engine: 5.7 / 7.4
Here's the LINKY for it.
Old Jan 25, 2004 | 09:16 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
never seen that on my car, or my truck.
Old Jan 25, 2004 | 12:31 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
My money's on Mass Airflow relay. Listed wires on Haynes diagram are Pink/black (which is supposed to change to black/pink, but I can see that not happening), orange/black, black/white, and brown (okay, so the brown's a complete miss).. about 3/4 wires. Nothing else comes close. Could be a part not represented on the diagrams..
Anyone else?
Old Jan 25, 2004 | 12:36 PM
Engine: 5.7 / 7.4
I removed that relay w/the rest of the harmess. It was by the power distribution block where the evap cannister was.
Old Jan 25, 2004 | 01:43 PM
TechSmurf's Avatar
Engine: LS1, Scrap
ooooookay.. then trace the wires
Old Jan 26, 2004 | 06:19 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wow guys, I'm shocked!
It's the timer unit for the rear defroster.
First activation gives you 15 minutes of defog until the timer kicks off, then the next activations only give you 10 minutes. I forget what the window is for the timer to reset and give 15 minutes again.
Old Jan 27, 2004 | 09:28 AM
Engine: 5.7 / 7.4
Guess I should leave it then, huh?
EDIT:
rainbow goes across screen w/caption, THe more you know
Old Jan 28, 2004 | 02:39 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
should have searched, hers MY post on the same thing from two weeks agohttps://www.thirdgen.org/techbb2/sho...hreadid=219107
Old Jan 28, 2004 | 04:18 AM
TechSmurf's Avatar
Engine: LS1, Scrap
really? That's what I need to replace in my v8? woot!
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
