How many miles dose your 2.8 have ?
Old Feb 22, 2004 | 02:30 PM
vodavi6346's Avatar
Car: 86 camaro b/coupe
Engine: HEMI! no 2.8 v6
Just woundering .. Mine has 34K right now .. I am thinking about painting it but don't know how much life the 2.8 has left ? .. its been well taken care of over the years needs new vaulve seals i think because it smokes on start up ... and the 700r takes like 15 seconds to kick in when car has sat over night .. think its a vacume pump ... but yea just woundering how many miles you 2.8 guys have on your cars
Old Feb 22, 2004 | 03:18 PM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
114 600 miles on original motor and tranny
Old Feb 22, 2004 | 04:16 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
My dads has 60k
Old Feb 22, 2004 | 07:25 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Its smoking with only 34k? Wierd. Anyway, if you are planning on fixing it, I'd say pull it out, fix the seals and paint it. If you aren't planning on fixing it, I'd say find a 3.4 long block and get that painted so you can do the swap in a weekend
Anyway, I've got about 40k
Old Feb 22, 2004 | 07:26 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
mine has 48K
Old Feb 22, 2004 | 07:53 PM
vodavi6346's Avatar
134k ! * lol .. yea .. wow you guys got some low miles
Old Feb 22, 2004 | 07:55 PM
mine's rebuilt though...
Old Feb 22, 2004 | 08:08 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
3.1 got pulled just shy of 200k (I'm guessing)
In goes 3.4 with 50-55k.
Old Feb 22, 2004 | 09:24 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
108.5k
Old Feb 22, 2004 | 09:26 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
135K and still lights em up and throws herself sideways
Old Feb 22, 2004 | 10:31 PM
RedTtop5spd's Avatar
Car: 99 SS
149K and spins em without a thought.
Old Feb 22, 2004 | 10:53 PM
br()bert's Avatar
Car: 85 firebird
show me a car with a manual trans that cant spin them
Old Feb 22, 2004 | 10:56 PM
Car: 99 SS
good point
Old Feb 22, 2004 | 11:33 PM
IROC-Z2814's Avatar
148k and some change. Its the original motor and tranny which has had a HARD last 30k miles on it. FPR finally went out in it but it still lights them up like its nothin It also beats the RX-7 in town too...he's scared of me now
Old Feb 23, 2004 | 12:24 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
mine had 140k on it, and was in bad need of going. when i pulled it out, the spark plugs were white (head gasket), the intake was leaking and so were the injectors. it was time to put er to rest. now i have a lovely 3.4 w/ 58k on it. running strong as hell and got a bit o stuff done to it w/ plenty left to do.
Old Feb 23, 2004 | 12:49 AM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
about 163,000 still doing ok for the most part
Old Feb 23, 2004 | 01:16 AM
87CamaroMan's Avatar
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
Well the 2.8 has 116k and its sitting on the garage floor ripped apart with collapsed lifters. The 3.4 has somewhere around 65k-70k
Old Feb 27, 2004 | 11:51 AM
UK Speedbird's Avatar
Car: 91 Firebird
Engine: 3.1L 191ci
Mines got 68.000 on original engine & gearbox and still run's like new. Only does 900 miles a year now it's with me due to the British weather!
Old Feb 27, 2004 | 12:12 PM
F585's Avatar
85K for an 85 Camaro all original.
Old Feb 27, 2004 | 12:34 PM
DHays's Avatar
Car: 89 Firebird
Engine: 2.8 V6
89 with 76k only things not blown so far are the motor and speakers since I got it less than a month ago! I belive the car wasnt driven very much and then I tried to make it a daily driver and sure (me driving it like its our G35 dont help much either!) Love the car to death tho gets tons of looks and comments its worth just having around for the atennion a older Fbody gets thats in good shape!
Old Feb 27, 2004 | 07:37 PM
WaynesRS's Avatar
Hey Tom , get your butt in here and post how many miles you have !
Old Feb 27, 2004 | 09:14 PM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
Transmission: 5-Speed
I've got you all.
282,000 miles, all original.
Old Feb 27, 2004 | 09:16 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
203,XXX on chassy, 75.XXX on new motor, too bad it wasnt a 3.4 replace ment
Old Feb 29, 2004 | 06:39 PM
84Berlinetta3rd's Avatar
Car: 84 Berlinetta
Engine: LC1 V6
Transmission: 5 Speed
24K Orig miles!...Denny
Old Feb 29, 2004 | 09:53 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
odometer showed about 142K plus change whenI had to scrap it. Cracked blocks are uncool.
Old Mar 1, 2004 | 10:50 AM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
189K Miles here. All original as well.
Old Mar 1, 2004 | 11:36 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: How many miles dose your 2.8 have ?
Wow, that's low! Keep going, you've got a lot of life left in that car- as long as you keep the engine tuned up Yearly. I've got 265,000 miles, original engine, 3rd trans, 2nd rear.
Old Mar 2, 2004 | 03:50 PM
bladz's Avatar
Car: 86 firebird
Engine: 3.8 turbocharged GN motor
149k all orignal motor and tranny and rear, tranny is starting to slip and motor burns oil but hey it all runs.
Old Mar 3, 2004 | 10:17 PM
tonkaman3's Avatar
Car: 1985 Sport Coupe
Engine: 2.8L
138K and still runs like a top. But I'm a gearhead so....383 stroker going in this summer. Maybe I'll donate the ol' 2.8 to a good cause! LOL.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
GouldyGTR
Sep 7, 2015 09:05 PM
