tranny
Old Mar 16, 2004 | 01:02 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
Transmission: 700r4 auto
tranny
what tranny comes stock in the 1990 v6 camaro rs automoatic? and also which tranny would i need if i wanted to switch to manual?
Old Mar 16, 2004 | 01:35 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
700r4
would need a t5 *cough, like in my siggy *
Old Mar 17, 2004 | 09:39 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
is this swap extremely complicated? and what all am i goin to need for this swap. i can only find info on puttin in new trans where the onld one was manaul cant find any info on automatic to manual thanks for the help guys
Old Mar 18, 2004 | 01:26 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
There is a tech article for this swap on this very site. When I did mine it cost me roughly $600 but expect to pay more. I spent almost a year collecting parts either new or from the junkyard. It was very tedious and is something I would never do again. The actual swap took me roughly 7 hours, but that was with a lift and air tools, and I had already installed the clutch pedal and cut holes for the master cylinder.
Old Mar 18, 2004 | 01:46 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Yes.. yes there is. Mine too was about $600, only $150 of which was invested into the trans/bellhousing. New clutch, flywheel, hydraulics, and a few bolts took their toll on the price tag rather quickly. Very tedious, but something I would do again if I had a good reason (T56).
*jumps up and down and curses profusely* .... you're lucky.. I did mine with a pair of ramps, a pair of jackstands, two hydraulic floor jacks, two scissor jacks, one lever jack, hand tools, a mechanically inclined potential girlfriend (hot chick crawling out from under car covered in grease *drool*), and a midget (for those hard to reach tranny bolts)
Old Mar 18, 2004 | 02:53 AM
Engine: LH0 3.1L
LOL, I never would have done it if I didn't have a lift to use. I sure could have used a hot chick to help me out though....
Old Mar 18, 2004 | 10:49 AM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
Wow, i didnt know it usually took $600 to do that swap. I did mine for aroudn $300 with a new generic clutch(its a v6 afterall), new hydraulics and a tranny at $85.
I did mine on a pit, yes, a pit, and i spread it out over a few days. Not extremely complicated but make sure you have the correct flywheel for your engine or you'll be ripping it back apart like I am.
Old Mar 18, 2004 | 10:13 PM
Engine: LH0 3.1L
$300??
Here's what I bought:
PROM $44
Transmission $55
Clutch $120
Shift **** $22
Shifter $10
Pedals $15
Flywheel $30
Flywheel Resurface $32
Speedometer gears $18
Clutch fork, stud, and boot $41
Rear main seal $18
Clutch master/slave cylinder $97
Vehicle speed sensor $49
Pilot bearing $0
Flywheel bolts $15
$566 plus anything I forgot.
All my stuff was either junkyard or new GM parts except for the clutch kit and shift ****. That GM clutch master cylinder actually costs about $170.
Old Mar 19, 2004 | 01:44 AM
TechSmurf's Avatar
Engine: LS1, Scrap
My main purchases:
Trans+Bellhousing+Clutch fork/stud/boot: 150
New Clutch Kit: ~100
New Flywheel: ~100
Hydraulics from GM: ~180
Bolts: ~40
Rear Main: ~20
Pilot Bushing: ~2
Pedals: Freebie
Shifter: Fabricated on a lathe (nifty)
Shift ****: Freebie
Center console top plate: ... does anyone have one of these laying around?
Old Mar 20, 2004 | 07:49 PM
sinfulwish's Avatar
Car: 1987 Camaro v6 2.8l MPI
Engine: one that goes "vroom vroom"
Transmission: one that shifts
Doh, posted my own topic before i saw this one, del please? hehe.
Approx how long of a job is it? If it could get done in like 3 hours, at a shop of course, i may be willing to pay an extra $200 to get it installed right the first time, ya know?
Old Mar 21, 2004 | 02:07 PM
Engine: LH0 3.1L
No shop is gonna do this for you, let alone in 3 hours.
Old Mar 25, 2004 | 06:24 PM
Axle/Gears: 4.10
CaliCamaroRS, why did you buy a prom? Do I need one? My car seems to be idling high. The RPM stay at like 1500 rpm when I let off the gas to shift. Would a PROM fix this?
Old Mar 26, 2004 | 08:04 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
im doing it right now....just got in the stuff to do it i ordered a kit from hawks thirdgen, cost me 660+76 for shipping.
all i got left to do is cut the new holes and put everything in woohooo
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
