Its fixed!!, who wants to guess?
Old Mar 29, 2004 | 06:39 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Alright, I have finally fixed my problem, :woot:
Shuddering while holding peddle steady, rpms bouncing, stalling occasionally at lights. Running rich.
I did..
checked, swapped, replaced every sensor on the engine.
vacuum steady at 18.5
fuel pressure little low, but shimmed to make up for it.
swapped (actually ran smaller injectors) injectors.
all fluids fine.
replaced alternator (was under warranty)
in process, removed smog and egr.
plugs new, wires fine, cap/rotor fine, coil fine
timing at 13deg
fuel filter replaced
NONE of this fixed it, who wants to guess what it was
tip, cost me 6 bux to fix it
drove it almost 100 miles yesterday, no problem, drove to work, didnt die in its ALWAYS spot. :lala:
Old Mar 29, 2004 | 08:32 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
EVAP CANNISTER FILTER?
Old Mar 29, 2004 | 08:59 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Do tell???
Old Mar 29, 2004 | 10:23 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oooh I love these! Um...
PCV valve?
Battery cable/ground strap?
(Shoot what else costs $6?)
A can of some kind of fuel cleaner/treatment?
Cracked intake duct?
Muffler bearing? Changed the air in the tires? Bottle of blinker fluid?
Old Mar 29, 2004 | 10:41 AM
Dale's Avatar
Engine: 350 S-TPI
Damn you tom, you guessed it.
Ground cable from battery to engine.
Old Mar 29, 2004 | 11:49 AM
Engine: 5.7 / 7.4
Ground cable....I have an extra one of those laying around here somewhere
Old Mar 29, 2004 | 12:01 PM
Dale's Avatar
Engine: 350 S-TPI
orielys had one too. Plus I had about 3 from my 3.4 swap in the s10, but they were side post, and I've converted to top.
I'm just happy its fixed :lala: Now whens that next autocross race
Old Mar 29, 2004 | 12:25 PM
KED85's Avatar
No wonder alternator went south!
Great detective work!
Old Mar 29, 2004 | 03:52 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
But how does it run? Lots more power than before? Will it break the tires loose now? Come on, don't hold out on us!
Eric
Old Mar 29, 2004 | 07:30 PM
Dale's Avatar
Engine: 350 S-TPI
Sorry eric, when it was running rich, yes, it would spin a tire. I put smaller injectors in it while finding my issue(s). I plan on doing some port work to my other intake, then install it along with the proper 17lb'ers.
Much smoother idle
noticable more power(should have more with proper injectors)
not sure on mpg yet as I have been working on issues,etc.
no more knocking, hell, half the time I have look at tack to see if its running
Old Mar 29, 2004 | 10:14 PM
KED85's Avatar
Boogie on down the Road!
How does the torque feel?
For all considering this 2.8->3.4 Long Block Swap Boogie, enjoy, it is a win-win situation.
Yeah wait until ya install the larger injectors.
I wouldn't hold at high RPMS until ya do install the proper sized 3.4 injectors.
Old Mar 30, 2004 | 07:06 AM
Dale's Avatar
Engine: 350 S-TPI
torque is noticeable, but still not what it was on the s10. I'm waiting on some exhaust work this summer
My car hardly goes over 4500rpm, very little over 4000. Just a around town, stoplight to stoplight car. I know the trans is slipping, so I dont hammer the peddle.
Going to work on new intake, then install injectors.
I currently have some other projects first. Ked knows what I'm talking about.
Old Mar 30, 2004 | 09:00 AM
Engine: 5.7 / 7.4
yes, please tell more on how that engine could've felt in my car
Old Mar 30, 2004 | 09:11 AM
KED85's Avatar
One thing I have noticed, as perhaps yourself, Dale.
The S-Series "Y" Pipe is a Hi FLo DREAM COMPARED TO THE LOUSY F BODY "T" PIPE!
Open your hood, look down at passenger side "Y" exhaust pipe junction & you'll see what I mean.
THANKFULLY Pace Setter Exhaust is including a fresh Hi Flo "Y" Pipe with the 3rd Gen V6 Street Legal Headers, coming soon to your car.
Old Mar 30, 2004 | 11:52 AM
Dale's Avatar
Engine: 350 S-TPI
Project, you really want me to? j/k.
I have done TONS of work to this motor since I got it from you. Head gaskets were about to blow, 3+ cups of mud in coolent system, intake loose, CSI leaking, bad timing chain, head job, polishing air passages and combustion chamber, all new gaskets.
S10 had headers on it, I'm hoping thats my "lack of power" that I'm use to having in these 6/60 mills.
Old Mar 30, 2004 | 01:44 PM
Slow2.8's Avatar
Ive been having the same problems... stalling at red lights and such, how can you tell if the ground cable is bad?
Old Mar 30, 2004 | 01:57 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
this sounds like (for 6$ anayway) somthing that should be replaced with a full tuneup. (i smell an amendment to my tuneup list.
Old Mar 30, 2004 | 02:13 PM
Dale's Avatar
Engine: 350 S-TPI
with it running, start shaking the cables. To even make situation worse, turn on headlights, radio, fans, anything that draws power.
Mine was because the wire would lay forward while hitting brakes. Causing bad connection inside. If your just sitting still, then it dies. IMO its something else. But like tony said, for 6 bux, its worth it just to get it off the list.
Old Mar 30, 2004 | 02:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Damn, and I thought I was reaching into left field on that one! Man, that sorta sucks... you've been chasing that for a while, checking out every system, and it was just a batt cable. At least you're good for a while!
Anyone ever try to get original GM batt cables from the dealer? I think my positive cable is a little fluky (had random power fails a few years ago- I could tell b/c the stereo would die, too)... but I want the side terminal cables with the red and black rubber covers over the terminals. Went to gm dealer and he told me that he couldn't get an actual part # for my car. He said I'd have to measure the length of the cable so he could order one- and my positive cable is like 6 feet long!
Old Mar 30, 2004 | 11:04 PM
KED85's Avatar
The dealer response is 100% correct.
GM stocks them to "lenght" and application (side/top post).
Old Mar 30, 2004 | 11:48 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Real dumb question.
Did you change the positive while you were at it???
Old Mar 31, 2004 | 05:39 AM
Dale's Avatar
Engine: 350 S-TPI
changed + one a little over year ago when I replaced starter.
I know why the ground one failed,
Old Mar 31, 2004 | 08:23 AM
KED85's Avatar
Last time I checked, smacking your forehead does not make a ground wire fail.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
85 Jimmy
Sep 30, 2015 07:56 AM
gta892000
Sep 16, 2015 12:37 AM
