list of mods, any suggestions ?
Old Dec 5, 2004 | 01:02 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
ok i've got my new engine and i'm getting ready to start buying parts, figured i'd put a list out and see if there any suggestions you guys have for it.
stock crank
block bored .30 over
heads ported
intake ported
plenum ported
crane 2030 hydraulic cam and lifters
stock pushrods
crane 1.6.1 roller tip rockers
stock oil pan
3.4ltr high flow oil pump
asp underdrive crank pulley
air and smog delete (hollow out pumps and leave them on)
pacesetter headers
new oem distributor
holley icm
msd blaster ss coil
thats the gist of it, now i need suggestions for pistons, springs, retainers, and what size injectors i should go with
Old Dec 5, 2004 | 11:31 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
piston crowns, valve faces, & cumbustion chambers thermal coated, piston skirts w/teflon. not asking too much are I??
valve job w/bigger valves,
get matching springs for cam,
windage tray,
see if gmpp catalog still has a good price on teh 3.4 ho cam kit.
Old Dec 5, 2004 | 11:40 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Might I suggest shotpeening the rods, knife-edgin' the crank, lighten up the valvetrain - lightweight pushrods, titanium retainers, etc... also go with a bigger cam (more around 220º @ .050, with about .510" lift) and more around 9:1 cr (slightly domed pistons), custom tuning, and extrude hone the hell outta the intake.
Should see close to 200-210 hp N/A on a 3.4!
Also, 2.5" mandrel catback exhaust!
Old Dec 6, 2004 | 03:02 AM
oil pan 4's Avatar
Car: 89 Firebird
Cross drill the crank and put leadin groves on the mains. Modifiy the main beraings and float the piston pins.
If you go with a bigger cam and more RPM's baffel the oil pan.
Old Dec 6, 2004 | 03:06 AM
oil pan 4's Avatar
Car: 89 Firebird
Grind the rods, I'll post picture on my car domain site of my newest rod mod.
I'm also going to ballance them to about 0.1g becasue I have nothing else to do when my Ohais gram scale comes in.
On page 7.
Old Dec 6, 2004 | 08:14 AM
Doward's Avatar
Balance to .1g? If I had my own scale, I'd have every single one of those rods balanced perfectly. .0g (Well, realistically, as close to that as possible - it's nice, because you can take as long as you want to work on it!)
Old Dec 6, 2004 | 10:40 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Did you end up getting a 3.4? Or did you get a 2.8 block?
Old Dec 6, 2004 | 11:47 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
got a 2.8, i have buddy up here with one for sale, but since i got the 2.8 i'm not gonna bother trying to get it. if your interested pm me
Old Dec 7, 2004 | 01:31 AM
oil pan 4's Avatar
Car: 89 Firebird
Get your engine custom ballanced because my stock rods are different by up to 2 or 3 grams.
I got my gram scale today also.
I will wait till I get my rod bolts to ballance them to less than 1.0 gram becasue the bolts could different by as much as .1g or more and same thing for the bearings, but I have to get the crank before I get bearings.
Linson
Sep 21, 2015 01:08 PM
64goatman
Sep 9, 2015 01:09 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Jk_Under
Sep 8, 2015 08:13 AM
84 TA NV
Sep 6, 2015 08:02 PM
