Aluminum Heads
Old Dec 13, 2004 | 07:09 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Aluminum Heads
So is it the general concensus around here that a custom intake will be needed to run fwd aluminum heads on a thirdgen 60* V6 ?
Old Dec 13, 2004 | 08:19 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
should beable to use the FWD intake, aslong as the upper section can be rotated 180 and still match intake runners. That is MOST of the fwd intakes
Old Dec 13, 2004 | 10:07 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
The FWD head are of a canted valve design, I dunno if the pistons have enought relief on a RWD block to accomodate them...
Old Dec 13, 2004 | 10:14 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
You can not just bolt the heads and go. 26.5cc combustion chambers vs 49.5cc
Old Dec 14, 2004 | 12:20 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
I just was asking because I noticed the 3.4 4th gen intake base looked to be a match for the fwd heads.
Old Dec 14, 2004 | 07:51 AM
Doward's Avatar
I haven't seen any pics of the 3.4 base intake... does anyone have any?
Old Dec 14, 2004 | 09:14 AM
Dale's Avatar
Engine: 350 S-TPI
3.4 base looks almost identical to our 2.8/3.1.
Has extra sensor hole up front (thats plugged) and doesnt have the CSI hole in rear.
Old Dec 14, 2004 | 11:29 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
So, I'm guessing that you mean even if it were done, the compression ratio would be jacked up so high, the car wouldn't run?
Old Dec 27, 2004 | 11:12 PM
1slow8t3's Avatar
Car: 83 v6 firebird
Engine: None right now
Transmission: none right now
Axle/Gears: 3.08 one tire fire
the compression ratio would be over 11:1 with the aluminum heads. Their has been some one that has done it on a f-body just can't remember who though (think it was on a 4th gen). The problem I see with the gen III topend is distributor clearance on the lower manifold.
Old Dec 28, 2004 | 01:39 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Raven did a Gen III top end in his 3.1 powered blazer... don't know where to find him anymore, though.
Old Dec 28, 2004 | 10:29 PM
1slow8t3's Avatar
Car: 83 v6 firebird
he went DIS with his though, so he diden't have any clearance issues with the distributor hitting the lower intake. he used the wiring harness and ECM form a 2.8 J-body and a home made crank trigger.
midge54
Dec 27, 2019 04:14 PM
italiano67
Aug 31, 2015 06:04 PM
bdads
Aug 24, 2015 06:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
