Rear Main Seal
Old Feb 27, 2005 | 09:36 PM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
Rear Main Seal
Im pretty sure it is, but is my 86 2.8 a Solid O Rear Main seal or the ( ) *two piece* Design? My clutch stopped working, and my bellhousing is super gooey compared to usual, and my oil level dropped pretty far without there being anything on the ground, so while im doing the clutch im changing my rear mail seal. Ive heard tricks how to do it, but only applies to the O Design. My friend says that in 86 they went to a O design over ( ) , I bet hes right, but I just wanted more opinoins. Thanks
Anyone know how much and what kind of fluid my T5 takes?
Old Feb 28, 2005 | 12:21 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
T5 = 2.5 qts of ATF fluid - I use Pennzoil Synchromesh, myself.
Your '86 should be a one piece (O) rear main.
Old Feb 28, 2005 | 08:19 AM
Car: 95 Z28
very nice I'll probally change that this week sometime
Old Feb 28, 2005 | 12:06 PM
Car: 95 Z28
My room mate says that he is pretty sure I would be a 2 piece Rear main. I have 4 diffrent people 2 are pretty sure its one way, 2 are pretty sure its the other way. My car was manufactured in June I think, would that make a diffrence?
Old Feb 28, 2005 | 12:20 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Did the 1 piece seal come along in 87 with the internal balanced motor?
Old Feb 28, 2005 | 12:22 PM
Car: 95 Z28
Im calling a Chevy Dealer right now, and they said:
1 piece and he said your 87 would be a 1 piece as well
Old Feb 28, 2005 | 03:57 PM
KED85's Avatar
Here's what ya get
GET THE CAM SHAFT REAR GASKET!! MANDATORY!
YOU GET A 1 PIECE ROUND SEAL for main crank.
INSTALL BOTH!!!!
MANDATORY on the cam shaft item!
Mine on my 3.4 was history & I was leaking like a broken dam.
MAKE SURE YOU GET GM STUFF! No aftermarket stuff items. GM over the counter stuff.
You'll do well now.
Old Feb 28, 2005 | 04:23 PM
Car: 95 Z28
why do I gotta do both? I gotta sell the car, so I really dont want to spend much money on it, I just want to get it running. I cant get the stupid transmission off, gotta have someone help me do that.
Old Feb 28, 2005 | 06:16 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
tranny isn't to bad to do alone. Long as ya got the car off the ground enough. take the tranny off, then the bell. Don't try to do it in one piece. But I did mine alone. Course Ive done auto trannys alone. Those are heavy. But if you got enough room, just drag it up on to your chest and bench it.
I think he mentioned the cam thing as it is the cause of the leak more often. Rear mains didn't go out that often.
Might be worth while to do em both and just tell the dude. Ya could of just ignored it to get it sold but did him a favor and changed it while you had it down.
So that's why you ain't budgin on price.
Old Feb 28, 2005 | 07:32 PM
Car: 95 Z28
Ya, I took the 4 bolts out to do it first without the bellhousing. WTF is that big counter weight looking thingy? that mounts directly under where the shifter goes up, and points back? And how do I take it off?
Old Feb 28, 2005 | 08:21 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
It bolts on somehow. I know its removable. Its a counter weight.
When ya shift n jump on it, The rear of the tranny wants to lift. That weight helps hold it down. as the up n down motion can cause damage or unwanted vibration.
Old Feb 28, 2005 | 10:03 PM
KED85's Avatar
The gasket is a few dollars more.
I wish I knew of this cam gasket detail when I just swapped in the 3.4 in my Blazer.
Oh well....
xxx3man`
Sep 23, 2015 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
