Cruise Control Problems
Old Apr 13, 2005 | 02:31 PM
87Bandit's Avatar
Car: 1987 Pontiac Firebird
Engine: 2.8lt V6
Transmission: TH700R4
Recently I changed the distributor oring because it was leaking like crazy. Well when i was putting it back in I broke part of the small T that connects the vacuum hoses that come out of the top of the manifold. I believe that one of them is an emmisions hose and the other is for the IAC or something because when it was broke the car ran terrible and had no power. Well i capped off the broken part of the tee and bought a tee from the parts store and spliced into the hose beside it. Well the car runs fine, but the cruise control doesnt work. I'm not real sure why it doesn't work or if it has anything to do with that vacuum line. Does anyone have any ideas as to why it doesn't work or if there is something around the distributor that i may have hit but didnt realize it to make the cruise control stop working?
Old Apr 14, 2005 | 10:25 PM
87Bandit's Avatar
Engine: 2.8lt V6
Anyone have any ideas of what may be wrong? Or could anyone tell me how the cruise control works or at least if it works from vacuum or not?
Old Apr 14, 2005 | 11:41 PM
Ice Fisherman's Avatar
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
Your cruise servo should have two vacuum hoses going to it. One is the vacuum source, and the other is a vent that goes through the firewall to a brake pedal switch. Since the cruise stopped working when you broke the connector, check and see if you are getting vacuum to the servo.
Old Apr 15, 2005 | 11:06 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
The tee off the manifold that you say you broke, if routed correctly, has nothing emissions related on it. The big hose that goes to the driver side is for the power brake booster and the smaller side goes to a hose, then another tee fitting. One of the fittings runs all the way over to the cruise control and the other goes into the firewall and is the vacuum source for all of the HVAC stuff(heater controls).
Old Apr 18, 2005 | 03:33 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
THis is a dumb question, but does anyone know how the damn cruise control works on a 90 camaro rs, I cannot figure it out
Old Apr 19, 2005 | 09:15 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
The ECM controls the cruise control modulator, which is located in the front passenger side of the car.
The ECM uses the VSS signal to calculate how much throttle the vehicle need to maintain the desired speed and applies vacuum to the modulator to pull in the cable and open the throttle.
Old Apr 19, 2005 | 02:31 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
I recently had my ecm replaced, but I still cant get the cruise control to work on my camaro?
Old Apr 19, 2005 | 04:01 PM
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
I have the shop manual with the schematic and diagnostic procedures, but it is 7 or so pages. Too much to post here. I can scan and e-mail it to you if you want.
Old Apr 19, 2005 | 06:23 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
That would be cool, here's my e-mail address, rebelgq@hotmail.com
Old Apr 19, 2005 | 07:04 PM
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
You've got mail
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
