dumb blonde needs help
Old Jul 29, 2005 | 02:01 PM
lena's Avatar
Car: 1985 firebird
Engine: 2.8L
Transmission: auto
got an 85 firebird 2.8, car startes fine sometimes than after running it and than turning it off car won't start ,it normally will start though after about 20 min of letting it sit, it turns over and i can smell gas but don't seem to be getting any spark, it's been like this for a few weeks now
Old Jul 29, 2005 | 02:15 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
It sounds like the first two places to start would be with your coil, and ignition module, they are cheap to replace, probably havent been replaced in a long time if at all and it wouldnt be a waste to replace them anyway.
Old Jul 29, 2005 | 02:19 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Pull the ignition module - Autozone can test it.
Check that first - then try the coil.
Old Jul 29, 2005 | 02:44 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Agree with both above.
Coil
ICM (inside the distrib, takes a 5.5mm or 7/32 socket)
Old Jul 29, 2005 | 06:10 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
^^What they said.
and
If you're gonna change those you might as well do a TomP tuneup .
Old Aug 9, 2005 | 05:09 AM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
I had the same problem when I had the 2.8, turned out to be that the choke pull-off was bad.
Old Aug 9, 2005 | 09:09 AM
KED85's Avatar
Replace coil.
Who will do the work?
Old Aug 9, 2005 | 12:01 PM
DeanE's Avatar
You are not putting enough Clarol mix in the fuel
Rally Smith
Sep 14, 2015 06:59 PM
NinjaNife
Aug 23, 2015 11:49 AM
elevario
Car Audio
Oct 2, 2001 06:49 PM
89PFB
Apr 25, 2001 07:53 PM
AcSeb
Oct 14, 2000 12:13 AM
