crank sensor
Car: 2002 ranger(showtruck) 90 firebird
Engine: 3.1l
crank sensor
i have a 1990 firebird with a 3.1l and am thinking i need a crank position sensor.(mechanic said could be my problem) was wondering the location or if i even have one. i cant find it and my hayes manual says nothing about it
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Your car uses a distributer. Inside the distributer is an LED sensor which "senses the camshaft." You do not have a CKS.
Transmission: 5-speed/T-5
As mentioned you don't have a Crank Position Sensor.
But the pick up is not optical, it is a magnetic trigger.
Originally Posted by Dirtbik3r
Ahh, my bad and I stand corrected. Magnetic trigger is gm's name for a permanet magnet sensor, right?
Originally Posted by Dale
Take it to a different mechanic, he doesnt know WTF hes talking about.
)I forgot to mention that in my last post.
Last edited by Six_Shooter; Apr 7, 2006 at 10:08 PM. Reason: Automerged Doublepost
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Magnetic Reluctor, that's what it's called. It has 1 set of fixed poles and one set that rotates with the shaft.
Hall Effect is when you use a metal vane to cut off electrical flow.
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: crank sensor
thought I might suggest looking at the date on a thread before you post. this post is 4 years old. 3.4s have a crank sensor, 2.8s and 3.1s don't.
