injector wires where????
Old Oct 9, 2006 | 06:47 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
forgot to mark the injectors on the rebuild...what ones go where?!?!?
Old Oct 9, 2006 | 07:44 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
someone correct me if I'm wrong, but the enignes are batch fire, so left side, lef, others right. They should "fall" towards which ever side they've been on for the last decade+
Old Oct 10, 2006 | 02:19 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Old Oct 10, 2006 | 07:42 AM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
heh........trial and error i guess lol
Old Oct 10, 2006 | 09:36 AM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
The wires are old enough and the wire lengths are specific enough that you can just lay them down and they will basically fall into place. I didn't mark mine when I did my 3.4 swap... I had no 2nd thoughts about what went where.
-Bud
Old Oct 10, 2006 | 11:43 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
same here, i have never labled them. if you place the other connectors on that harness where they go the injector wires should be close enough to figure out.
and project: they ARE batch fire. left side right side. on my TPI it's the same way. infact about halfway up the harness the one wire splits into 4 (or 3 on a v6) and goes from there.
Old Oct 11, 2006 | 09:42 AM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
what do you mean by batch fire....i remember if i looked correctly, that one of them split wires had 4 on one side..?
Old Oct 11, 2006 | 10:45 AM
Engine: 5.7 / 7.4
batch fire, all the injectors on one side fire at same time, ten other side fires at same time
Old Oct 11, 2006 | 06:53 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
how the hell does that work....i cant make sense of it.....i believe you and all i just dont understand it..
Old Oct 11, 2006 | 08:10 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
About every i think it is 180 degrees of crank rotation 4 injectors pulse ( left or right side), then the next 180 the other side will pulse all 4.. continuous pattern
Although i think the v6's are SFI?
Old Oct 11, 2006 | 09:27 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
so it seems as if that there is being gas used improperly??? confused!
Old Oct 11, 2006 | 11:18 PM
Supermann's Avatar
Car: '86 Camaro, '85 Z28, '92 Firebird
Engine: LB8 2.8, LG4 5.0, LO3 5.0
Transmission: TH-700R4, T-5, TH-700R4
Axle/Gears: 3.42s, 3.23s, 2.73s
Yea, gas is wasted with MPFI, and SFI didn't come out until '93 with the 3.4s in fourth gens. SFI only fires the appropriate injector for the cylinder that is going to be fired next. Thats why the heavier 4th gens with the bigger v6s still had good MPG ratings. Another reason to swap to that setup besides the speed density benifit.
Street Lethal
Apr 30, 2019 12:14 PM
jklein337
Sep 19, 2018 06:23 PM
Jae992
Aug 27, 2015 09:07 AM
Brcharrelson
Aug 26, 2015 07:47 PM
Bryan F
Aug 18, 2015 02:28 PM
