2.8 -> 3.1?
Old Nov 8, 2006 | 12:24 AM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
Transmission: stock BW 5 spd.
Axle/Gears: stock 3.42
2.8 -> 3.1?
my car has the stock 2.8 in it, my nephew has a 3.1 out of a FWD car, & he says it'll bolt right inplace of my 2.8 without any mods...
1. is this true?
2. should i do it?
3. would i notice any difference?
Old Nov 8, 2006 | 01:11 AM
daves12secV6's Avatar
1. is this true?
2. should i do it?
no a fwd motor will not bolt right in,the internals are the same,except the engine mounts on the block are diff and the starter is on the wrong side of the engine
Old Nov 8, 2006 | 01:16 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
NO! Fwd uses a block with different engine mount points. they also use a different ignition system. If the engine has the Alum heads you would also need the whole ECM fromt the FWD car to get it to work as well.
So if you had the resources to make special mounts to adapt the FWD to RWD yes you could use the FWD engine, but if it is a newer engine with the DIS ignition system IE Alum heads you will need to whole computer system for it.
EDIT: i didnt know about the starter. wonder if you could adapt that some how.
Old Nov 8, 2006 | 05:20 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
first next time since its been covered about a billion times please!!!
Old Nov 8, 2006 | 05:38 AM
diablo666mew's Avatar
Car: 89 camaro RS convertible
Engine: 305 tbi
no a friend of mine tryed the same thing it will not work!!!!
Old Nov 8, 2006 | 08:12 AM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
ok heres a ? that on but off subject.
I have an 84 block in my bird and have a 90 grand am 3.1, what would it take to swap the guts?
anybody know the jurnal sizes between the cranks and bore on pistions?
is there v8 parts that'll swap in the pistons and rods?
Old Nov 8, 2006 | 08:40 AM
Engine: 305 tbi
cant help u there sry
Old Nov 8, 2006 | 09:09 AM
BIRD-VERT92's Avatar
Car: 92 Firebird vert
Engine: 388ci
Axle/Gears: 3.23 open
I've got a good running 3.1L complete. just pulled it out of a 92 firebird. 116k miles, runs perfect. 100.00 plus shipping.
Old Nov 8, 2006 | 09:19 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
throwing some stuff out there for this thread....... if the car has the vss setup, and a manual....... fab up teh engien mounts to work & use a tranny from the 3800 f-bods as the starter is on the other side.....
back to topic
journals onteh 3.1 should be bigger, as the 85+ got the upgrade. v8 rods look to be the same as sbc, going off of this: https://www.thirdgen.org/forums/v6/2...ighlight=bible
Old Nov 8, 2006 | 09:25 PM
back to topic
not a standard large journal the pin end and crank ends are 2 big.u have to get a set of small journal 327 sbc rods and then u have to have the ends machined to enlarge them,for them to fit.
there is no real reason to change out the rods anyway,the stock ones are plenty strong prolyl hold upto about 475hp if u dont rev over 6,500-7000
Old Nov 9, 2006 | 05:43 AM
Car: 91 RS
Engine: 5.0 tbi
well I was more so wondering about pistons . something in like a flat top 2 relief would be nice
Old Nov 9, 2006 | 08:01 AM
firstfirebird's Avatar
ineterested
Could you get a quote to 33065?
Does it include the ecm and accessories?
Old Nov 9, 2006 | 10:20 AM
Engine: 388ci
probably around 125.00 freight. I still have the ecm in the car right now. Gonna keep it until I figure out all the guages, pumps, fans etc.
Old Nov 9, 2006 | 04:35 PM
pm sent
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
