torque convertor stall speed & rear axle gear selection
Old Nov 15, 2006 | 09:47 AM
stormin's Avatar
Looking for info on stall speed & rear axle gear selection. I've got an 11562 hypertech chip (86-87 V6),crane 2030 cam w/.423 lift, MSD blaster coil,headers. I have 9-bolt posi with either 3.27 or 3.70 gears but unsure of what stall speed convertor (plan on adding a shift kit to stock (700r4) tranny) should I use a lock up convertor? & what size tire? I have 15 & 16 inch wheels (stock type). This car is occasional street use only. Any help is appreciated.
Old Nov 15, 2006 | 02:03 PM
Supermann's Avatar
Car: '86 Camaro, '85 Z28, '92 Firebird
Engine: LB8 2.8, LG4 5.0, LO3 5.0
Transmission: TH-700R4, T-5, TH-700R4
Axle/Gears: 3.42s, 3.23s, 2.73s
so are you saying you have 3.27 gears, or you have 3.70 gears? or do you have a choice between the two?
Old Nov 15, 2006 | 03:31 PM
stormin's Avatar
I have both sets of gears.
Old Nov 15, 2006 | 04:02 PM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Definetly go with the 3.70's with the v6 motor, the more rpm and mechanical advantage the better, especially with a cam. .423 isn't especially aggressive, whats the duration like? I would think a 2500rpm stall would be adequete for street/strip use. A lockup converter is always nice if you care about fuel mileage and wear and tear. What is your overall goal for the car, that'll help figure out better which way to go?
Old Nov 15, 2006 | 04:18 PM
daves12secV6's Avatar
3.70 gears,26 inch tall tire with a 2,400-2,600 stall speed,and yes use the lockup converter.
Old Nov 16, 2006 | 08:43 AM
stormin's Avatar
Cam degrees of duration @.050 lift 204/Int & 214/Exh. Want a dependable mild drag/road race/autocross type vehicle that could be driven to & from the track if necessary. Recommendations on brand of convertor? Thanks for your replies.
Old Nov 16, 2006 | 03:12 PM
vigilante tq converter,is the only place i know of that has a converter that fits the v6 trans,unlessu send out the stock one to get restalled.
a reg 700r4 converter does not fit the v6 trans,u need a 9.5 inch converter to fit it
Old Nov 16, 2006 | 03:15 PM
atc3434's Avatar
Car: 1986 Camaro SC
I run those same cam specs with my 305, it works well with a 2500rpm stall and 3.73s. I think with the v6, the more gear the better, and plenty of converter too! Those would be completely streetable as well, especially with a lockup converter. Got any numbers on the motor? I'm always curious.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
InfinityShade
Aug 22, 2015 08:00 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
