91 RS Motor Mounts
Old Jun 11, 2007 | 08:06 PM
project91rs's Avatar
Car: 91 Camaro RS
Engine: 3.1L MPFI
Transmission: 700-R4
91 RS Motor Mounts
Hey everyone. got a 91 rs 3.1 which has a bad right motor mount. never changed one before so any advice would be greatly appreciated. thx
Old Jun 11, 2007 | 10:44 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: 91 RS Motor Mounts
PITA! You gotta romove both bolts holding the motor in, then remove the distrubutor...or at least the cap. Then you can jack the engine up enough to get to it.
Old Jun 12, 2007 | 10:02 AM
Car: 91 Camaro RS
Engine: 3.1L MPFI
sounds like fun! thanks for the reply 2point8
Old Jun 12, 2007 | 10:08 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I didnt remove the dizzy when I did it on my v6. But did have to jack that side up. Long nosed pliers, magnetic finder, and some other normally odd tools are your friend.
Old Jun 12, 2007 | 11:02 AM
firebirdland's Avatar
Car: 91 ,82 trans am 79 t/a
I've pulled 4 of the v6 engines. easy job. are u pulling the tranny w/it? The only tricky part for me was getting the torque arm to line back up to tranny. the distibuter should come off. the cap that is. watch out for the temp sensor on the passinger side of motor, by the firewall, i've boke 2 of them pulling the motor out. good luck
Old Jun 12, 2007 | 11:15 AM
Dale's Avatar
Engine: 350 S-TPI
Your pulling the whole motor out to swap motor mounts? Thats alot of extra work IMO.
Old Jun 12, 2007 | 01:12 PM
Car: 91 Camaro RS
Engine: 3.1L MPFI
no, i'm not pulling the motor to change the mounts. just gonna jack it up and replace them. i can see where i will have a clearance issue with the dizzy cap, so that'll have to come off. thanks for all the input guys!
Old Jun 12, 2007 | 03:31 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
as soon as im back home and near a hoist, im looking into putting my poly mounts in that ive had for over a year. i tried to one time, but only had a total of 4 hours to do both, and its not an easy task, i ended up putting it all back together and not getting it done, lol. youre gonna need a long extension to get at the nuts on the bottom side of the frame THROUGH the coil spring, along with a swivel of some sort.
Old Jun 13, 2007 | 02:42 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
I used a ceiling hoist to lift the engine up and then took the motor mounts off. I didn't remove anything at all to do it. Kind of a pain, but really not that bad.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
