pulling the engine out
Old Sep 26, 2007 | 11:10 AM
xsupermann69x's Avatar
Car: 1991 Chevy Camaro RS
Engine: V6 3.1L
Transmission: automatic
So in about 2 weeks me and my dad are going to be pulling my engine out of my car so that we can fix a leak in the rear main seal is our guess. while its out i wanted to know what easy things that i could do to add a little bit of power. and we will have a total of about 3 days to do the whole pull out put back in fix the leak. let me know. my dads a retired mechanic so he knwos what he is doing just want all of your opinions on what exactly i should add to give me that little more power. its a 3.1 v6.
thanks for all the help ahead of time.
Old Sep 26, 2007 | 12:31 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: pulling the engine out
Headers would be a good start, maybe a mild cam too.
Old Sep 26, 2007 | 12:38 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Possibly replace the oil pump.
Any budget?
Old Sep 26, 2007 | 03:01 PM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Replace rear cam seal. It right abouve the rear main seal. When I pulled my engine through it was a rear main but ended up being both the rear cam seal and rear main.
Replace distributor shaft O ring.
Replace oil pan gasket / Freeze plugs
Delete collant by pass lines.
Old Sep 26, 2007 | 03:10 PM
DaSkinnyGuy's Avatar
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
Replace the whole engine with an LS1 LOL. But I would get a cam, Headers you can do but your smog pump wont be connected to the headers. Add bigger fuel injectors.
Just curious how many miles are on your motor because I believe I am having the same problem.
Old Oct 22, 2007 | 01:04 PM
Engine: V6 3.1L
the odometer just hit 150,000 but we think it might have been messed with before like taken apart and put back together shitty or something. but yeah 150000. yeah i was plannin on doin a cam. whats the smog pump?
Old Oct 22, 2007 | 02:09 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
The smog pump is right below the alternator. It puts air into the pass exhaust manifold right below the EGR. The headers do not have the provisions to hook up the 3.1 system.
Old Oct 24, 2007 | 07:22 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
maybe i missed it, but if you dont have smog regulations, you dont have anything to worry about. cam is a good start, with a good mechanic at your disposal, headers are another good upgrade (as well as dynomax catback and some high flow cat to go with those). you can pull the valve covers and put on a higher ratio roller rockers, put in a 180 t-stat, delete the AIR pump (if you have it). there are a ton of upgrades you can do, just do a search and you can find more info that you ever wanted, i know i have, lol.
Old Oct 30, 2007 | 04:29 AM
Cratemaster's Avatar
Car: 1984 Camaro Sport Coupe
Engine: 2.8 L v6 (Carbureted)
Transmission: Automatic
I know Pacesetter makes headers for your vehicle that have connections for your smog pump, here in California, the smog pump, must be hooked up and functioning, although you can find a smog shop that will over look if you want to chance a smog pump delete. I'm not sure, but headers might even be illegal for street use in CA, leave it to those tree-huggers to kill the manly spirit of cars. LOL
Old Oct 30, 2007 | 04:47 AM
1bad86z28's Avatar
Car: 86 I.R.O.C.
Engine: 40 over TPI 305
Axle/Gears: 3:73
If money is "no object" Throw on a turbo system, that will pull some power out of that V-6.
Seriously though, if you can get rid of the emission stuff.
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
