Chip it or no?
Old Dec 25, 2007 | 10:47 PM
Fire&ashborn's Avatar
Car: 86' Firebird
Engine: 2.8L V6 fuel-injected
Chip it or no?
i have a 2.8L V6 fuel-injected firebird and i was wondering about performance parts and upgrades..it came to mind to put a computer chip in it..yes or no? n wat kind? really dont know much about chips and any other ideas welcome
Old Dec 25, 2007 | 10:53 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Re: Chip it or no?
My two cents on chips are that they don't make much difference on most vehicles. On some, maybe, but I would rather spend money on hard parts like helping intake and exhaust flow for starters. Obviously before anything I would give your engine a good tune up if it needs it, and go from there.
Maybe somebody on here has experience with aftermarket chips on a 2.8.
Old Dec 25, 2007 | 10:55 PM
Car: 86' Firebird
Re: Chip it or no?
alright thx i was already starting my tune up and everythign else..i actually have time n a lil cash flow to do my tune up, timing, brakes, oil, etc..just basics to get it in a better conditon n then doin my mods
Old Dec 25, 2007 | 11:29 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Chip it or no?
Most chips are worthless, and even the "good ones" only gain a few horse power, which IMO is not worth the expense.
Old Dec 26, 2007 | 11:49 PM
nixon5's Avatar
Car: 86 F-Bird
Engine: 2.8L v6
Re: Chip it or no?
every engine is different so unless your making a chip for your specific engine you wont see any gains in power.
Old Dec 27, 2007 | 06:17 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: Chip it or no?
Spend the cash you would on an aftermarket chip to get the stuff to burn your own. You only need $120 for a willems burner and a moates aldl cable. Another thing to note is that the factory maf v6 computer is a piece of crap. You can do a little tuning with it, but you're more or less blind unless you have a scanner because there's no publicly available aldl definition file. I converted to a '165 (tpi v8) ecm so I have full control of the tune. I'm going to do a writeup on the swap after I get a wideband O2 so I can fine tune it.
Old Dec 27, 2007 | 06:28 PM
Re: Chip it or no?
What ECM is used? Mask?
Old Dec 27, 2007 | 06:54 PM
bl85c's Avatar
Car: '85 maro
Re: Chip it or no?
The stock '86 ecm is either an '870 w/ $1F or a '302 w/ $3A. Most likely he has a '302.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
