Oil all over driver firewall, exhaust manifold
Old Feb 4, 2008 | 08:45 AM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Was driving to work this morning when the car starts smoking... I managed to get to work, parked it, and popped the hood. There's oil(still honey colored) all over the driver side firewall and driver exhaust manifold(which was causing it to smoke). I couldn't really tell what happened. What in the world just blew that spewed oil everywhere?
Old Feb 4, 2008 | 09:15 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Oil all over driver firewall, exhaust manifold
valve cover gasket? oil fill cap not secured?
Old Feb 4, 2008 | 09:30 AM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Check the rear cam cover if its not the valve covers.
Old Feb 4, 2008 | 09:36 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Axle/Gears: ?
1 check oil lvl in engine.. see if with in limits 2 wipe up oil 3 start engine look for leaks
Old Feb 4, 2008 | 09:38 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Sounds like you blew a valve cover gasket. With that in mind check your PCV valves and maybe replace them if they havn't in a while, they could be clogged. If you valve cover gaksets are good then see if your valve covers were loose and check the rear cam seal.
Old Feb 4, 2008 | 10:05 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I'm thinking if it got all over the side of the engine bay, IMO its something else. That would take alot of pressure. I have had VC leaks and it doesnt sling it. Just rolls onto manifolds and creates a smoke show.
Check dizzy gasket
vc gaskets
head gasket
pvc hose
I would possibly check other fluids as well.
Does it sputter any now?
Old Feb 4, 2008 | 10:22 AM
xbcrguy182x's Avatar
Is there oil dripping down from the valve covers? When was the last time you changed the oil?
Try, cleaning up the oil around the valve covers, let the engine run and see where its coming from.
Old Feb 4, 2008 | 10:43 AM
forkvoid's Avatar
No oil on valve covers. Last oil change was 300 miles ago(this engine is still in break-in period, it's right about 1300 miles right now).
No sputter. I've never seen a failed valve cover gasket spew oil like this either. It's not exactly on the side of the engine bay, it's on the driver side firewall and driver side exhaust manifold. Something flung the oil back onto the firewall pretty bad; there's not any on the driver wheel well at all.
Engine ran itself dry from how much oil it lost. I'm going to pick up several bottles of oil over lunch just so I can get this thing home(four miles).
Seems I've got several votes for the rear cam seal. Is it possible to see that seal without pulling the engine?
Old Feb 4, 2008 | 12:03 PM
Dale's Avatar
Engine: 350 S-TPI
Rear cam seal, you have to pull the bellhousing. I dont see how it would get on the firewall.
I would go for dizzy.
Also could go for not sealing up the rear of the intake manifold well enough since its on breakin.
Wonder if the OPSU could have cracked and is spraying at the "right angle" to get it back there? Thats a buttload of pressure!
Clean it up, then have someone start it while you inspect.
Old Feb 4, 2008 | 12:08 PM
forkvoid's Avatar
The OPSU might be an option... I have a mechanical gauge hooked to it and the pressure never dropped, so perhaps not?
The intake is well sealed, last time I was in there. I originally had that problem, with the LIM not being sealed on the block and was losing a ton of vacuum. I replaced the gasket and sealed everything with enough RTV to stick a gator's mouth shut. That was at 50 miles on the rebuild or so. I'll check the dizzy when I get it back home.
Old Feb 4, 2008 | 01:27 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
May sound kind of obvious but i made the mistake of changing the filter and the rubber ring didn't come off with the old 1. Put the new one on and oil shot everywhere.
Old Feb 4, 2008 | 02:01 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I had a valve cover gasket that blew and spewed oil all over the driver side engine bay and firewall just like the OP is describing.
Old Feb 4, 2008 | 02:54 PM
forkvoid's Avatar
That's interesting. What caused the gasket to blow? I'm using the FelPro rubber ones.
Old Feb 4, 2008 | 03:03 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Bad PVC valve and cork gaskets.
Old Feb 8, 2008 | 06:48 PM
forkvoid's Avatar
Pushed the car out of the carport tonight to clean the carport... cream colored liquid was under the engine. Head gasket is trashed on the driver side. Have no idea why, since the engine is such low miles.
On the bright side, there's two 3.4s in the junk yard right now.
Old Feb 8, 2008 | 06:56 PM
Damn, how many miles was on the engine?
Old Feb 8, 2008 | 07:29 PM
forkvoid's Avatar
1200-1300. Fresh rebuild, that's why I'm so stumped as to what would have caused it to blow.
Old Feb 8, 2008 | 07:37 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Did you reuse the old bolts?
transaero
Aug 31, 2015 01:14 AM
Navy8125
Aug 21, 2015 09:32 AM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
