FWD 3.4l v6
Old Dec 13, 2008 | 04:58 AM
bejitto101's Avatar
Car: '89 Firebird
Engine: v6
FWD 3.4l v6
Couple of questions. I'm new to the forums, and cars in general, so my apologies if this sounds stupid.
The sticky for v6 engine swaps says that FWD engines are a pain to put in and require a bunch of work. I was just curious what type of work they require to make them fit? O searched the forums and didn't find much.
I just found what I consider to be a nice deal on a 3.4 v6 in craigslist, but it turns out its the LQ1, which is FWD. It does put out a nice 215 hp according to wikipedia. Here's the ad: http://seattle.craigslist.org/sno/pts/955483228.html What would you guys consider a good deal on a 3.4?
Old Dec 13, 2008 | 07:09 AM
bmxerboi221's Avatar
Car: 1988 Firebird
Engine: soon to be 3.4/3400
Re: FWD 3.4l v6
To start off not sure if the transmission will bolt up, along with custom motor mounts and the starter is on the wrong side. You might want to check out the 3.4l RWD motors not as much power as the FWD but everything bolts up even your intake. You could always turbo and easily reach that 215+. Good luck with your search though!
Old Dec 13, 2008 | 07:43 AM
firstfirebird's Avatar
Re: FWD 3.4l v6
The LQ1 is a DOHC. Even More difficlut to swap than a FWD pushrod motor.
Easiest thing for us to do at the moment is to use the top end and pistons from a FWD in our blocks. 3.4 Fbody RWD motors are better equipped to do so with the DIS reluctor wheel in the crank.
Old Dec 13, 2008 | 05:46 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
Re: FWD 3.4l v6
I have one of them motors partly installed in a third gen. It needs custom motor mounts, two notches in the crossmember for the alternator and a/c compressor, and the cam boxes hit the firewall, wiper motor, and heater box. The V6 trans will bolt right to the motor. The starter is on the drivers side and gets in the way of the oil filter. I may go back to working on the swap after I finish my LT1 swap.
Old Dec 13, 2008 | 08:43 PM
project89's Avatar
Re: FWD 3.4l v6
got any pictures of it???? i was toying witht he idea of doing this swap and then turbo it after it was in. might actually steer me away from doing my 4.3
Old Dec 14, 2008 | 08:38 AM
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Re: FWD 3.4l v6
Moving the engine forward an inch would help most of the problems but would probably create more problems. I will try to get some pictures of the mounts I made later today. I believe in the picture the engine is sitting on stock mounts.
Old Dec 14, 2008 | 11:27 AM
project89's Avatar
Re: FWD 3.4l v6
nice thanks,yeah please if u could get some more pics of mounts and what is hittin on the crossmember. i have a soloution for the heater box already but it requires ditching the ac
https://www.thirdgen.org/forums/fabr...-c-delete.html
how much is it hitting the firewall in one spot,(big hammer to knock it in or does it need to be cut and notched)
wiper motor hell my wipers dont even work no big loss there
Old Dec 14, 2008 | 11:44 AM
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Re: FWD 3.4l v6
you could probably hit the firewall with a big hammer to clearence it and it only hits the crossmember if you want to use the stock a/c compressor mount and alternator mount.
Old Dec 14, 2008 | 11:49 AM
project89's Avatar
Re: FWD 3.4l v6
ac would deffinatly get ditched. im ahave to go dig up some pictures of the accesories mounted to the motor.
the alternator mount is part of the front engine cover isnt it?
Old Dec 14, 2008 | 11:52 AM
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Re: FWD 3.4l v6
yes they are mounted real low
Old Dec 14, 2008 | 11:56 AM
project89's Avatar
Re: FWD 3.4l v6
hmm ok that poses one problem, but dosent seem like to big of a deal to somehow move the alt.
oil filter can be relocated using a remote oil filter system so thats pretty easy
lol i think u just stoped me from putting a twin turbo 4.3 in my car.
dam junkyard closes in 5 mins lol or id be running over there to see what they got.i know they had abunch of cars with the lq1 in it last time i was there 3 weeks ago
Old Dec 14, 2008 | 02:09 PM
mexicanknight's Avatar
Re: FWD 3.4l v6
that seems interesting could you post more info in that swap?
Old Dec 15, 2008 | 02:27 AM
project89's Avatar
Re: FWD 3.4l v6
i should know by wensday if im getting one or not friend of mine is gonna hit the junkyard and go look for me/ these motors came in what the monte carlo/there was a mini van too and what else
Old Dec 15, 2008 | 09:15 AM
bejitto101's Avatar
Car: '89 Firebird
Engine: v6
Re: FWD 3.4l v6
Old Dec 15, 2008 | 01:31 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: FWD 3.4l v6
hmmm quad cam would be sweetass, that thing will sing :-). i considered getting a quadcam 3.0 v6 cosworth lump, they made for some old ford granadas - uk - 210hp stock , lots of work using an engine built for a ford but the end result would be a cosworth firebird and that just sounds sweet :-)
Old Dec 15, 2008 | 01:37 PM
project89's Avatar
Re: FWD 3.4l v6
the heads on the lq1 outflow any other 60* head by tons, the expsensive part of building one of thos emotors is cams, u pretty much have to go custom and instead of paying for one cam ur paying for 4.
i looked into this motor a while back but never thought much of it cause i didnt know a whole lot about it but now that ive seen somone else actually get one into a f-body, i deff think this is the way im going to go.
gonan suck to lose the dizzy though, i liked being able to have antilag and spark cut, if i do the lq1 ill have to goto a ford edis wasted spark system, which u cant do a spark cut on, but aparently with an msd box u can so im still looking into that
Old Dec 24, 2008 | 08:33 PM
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Re: FWD 3.4l v6
Finally got a chance to take a picture of the mounts I made. The stock mounts would work with a little work. If I remember correctly the left mount bolts on and the left one needs a tab welded to the front. The mounts I made clearance for the alt and a/c comp. I move the frame mount back 1" to allow for the a/c lines and mount bolt. Mike
Old Dec 24, 2009 | 10:57 PM
thmpsn70's Avatar
Car: 1991 Z28, 1980 chevy monza
Engine: 305 tpi in the camaro 3.8 in the mo
Transmission: auto
Axle/Gears: 273 posi
Re: FWD 3.4l v6
Thats funny to see someon mention cosworth, I drive a cosworth vega right now that I am swapping for a 1992 firebird ragtop with a v-6 and looking at those pics it looks like a v-6 version of my 4 cylinder I have right now(till the guy gets the bird out of the mud in his driveway) but I tell you the cosworth vega equipped with the twin cam , 4 speed and 3.73 posi is badassfor a 4 banger,Timmy
Ryan_Alswede
Sep 10, 2001 12:31 PM
Drew
Sep 4, 2001 11:49 PM
WideOpenVTwin
Aug 2, 2001 09:38 AM
Red91Bird
Mar 28, 2001 09:39 PM
Mike Harvey
Feb 2, 2001 06:42 PM
