getting my first v6 2.8 HELPPPP
Old Mar 1, 2009 | 11:08 AM
  #101
jaybdaboat's Avatar
Car: 1987 Sports coupe/z28
Engine: 2.8/ swapping 5.3
Axle/Gears: Open 3.42
Re: getting my first v6 2.8 HELPPPP
Originally Posted by chevyracingrox
did you hold it upside down when you cleaned it out? its very important. it's also very important that you wait until its completely dry before using it again. more likely that it's the IAC, was it running alright before you cleaned it?
it was already running like sh*t before i did it, and yes i cleaned it right
Old Mar 1, 2009 | 11:14 AM
  #102
jaybdaboat's Avatar
Originally Posted by K-slice
O2 sensors should be replaced regularly any way. They dont stay good for very long.
This sounds like the same thing that was wrong with my car when I first bought it. I did everything you mentioned to try and fix it but nothing worked. Finally I took it to a shop, who told me my fuel injectors were shorting out and buring my PCM. I got new injectors and a reman. PCM, fixed the problem right up. I hope this isn't whats wrong with yours since this cost a good abount of money to fix...
so could the o2 be da problem?
do i need to get a new one and my car will be working fine again?
and how would i no if its my injectors
Old Mar 1, 2009 | 11:24 AM
  #103
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
o2 could be it, worth a try. finding if it's the injectors shorting out is pretty easy. open the hood at night, or in a dark garage, spray water around your fuel injector connectors start the engine and see if you get a light show. if its arcing around they're shorting out.
Old Mar 1, 2009 | 12:26 PM
  #104
jaybdaboat's Avatar
do i have to take off the intake manifold or can i do this with it on?
and if so could u take one of the pics and tell me where to pour the water
Old Mar 1, 2009 | 12:40 PM
  #105
no just leave the manifold on. spray some water from a spray bottle or something under the top of the intake manifold, just so there's moisture where the fuel injectors plug in. water is acting to help the electricity short the injectors, if they aren't being shorted out, nothing will happen. it might do this without water being added, if you wanted to try that to, just turn off the lights in the garage and look for lightning while the car is running.
Old Mar 1, 2009 | 03:08 PM
  #106
jaybdaboat's Avatar
ok i just came back from gettin my car looked at
and its my fuel regualtor(sp?)
so i gotta get the parts for that
then labor
Old Mar 1, 2009 | 03:28 PM
  #107
you have a couple of options. you can get a stock fuel rail that already has one from a jy, you might be able to order it from a dealer (but might not either, it was considered a part of the fuel rail and not serviced if defective the rail was replaced), or get an aftermarket adjustable one. not too bad to install, if your feeling brave.
Old Mar 1, 2009 | 03:39 PM
  #108
jaybdaboat's Avatar
i dont like buying over the phone or offline for that i spent that money then i want it now
but is a hard to do cuz it would save me 50 dollars
Old Mar 1, 2009 | 04:04 PM
  #109
its not too bad. you have to remove the upper plenum (manifold) and the fuel rail. you might be able to get a fuel rail with injectors for cheap, but if you don't its no big deal. I'll post up a picture showing you what to disconnect to get the plenum off. at first it seems like a lot, but once you do it about a hundred times, its really simple.
Old Mar 1, 2009 | 11:20 PM
  #110
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Hey! That was wrong with my car too, with all the other problem I mentioned earlier. They replaced the fuel pressure regulator to fix that problem.
Old Mar 2, 2009 | 08:22 AM
  #111
jaybdaboat's Avatar
pics please?
Old Mar 2, 2009 | 08:24 AM
  #112
jaybdaboat's Avatar
so did u really need to replace a fuel injector, those things are expensive
Old Mar 2, 2009 | 08:50 AM
  #113
got it modded. you'll have to remove the EGR tube also, but its pretty simple. take off the vacuum lines on the back, unbolt those 5 bolts on each side, unbolt the throttle bracket, 2 bolts on the front of the throttle body, take off the throttle cable attatchment on the throttle body. Its a clip, you can just press it down and it'll come off, I'm sure you'll figure it out. lift that off and the fuel rail is held in by 2 bolts. press on the screader valve to relieve pressure. disconnect the fuel lines and use a screwdriver to pry the rail and injectors out little by little.
Old Mar 2, 2009 | 08:54 AM
  #114
forgot to upload the pic
Old Mar 2, 2009 | 09:49 AM
  #115
jaybdaboat's Avatar
i need to take out the fuel lines and injectors? to remove and insert the new fuel pressure regulator?
Old Mar 2, 2009 | 10:52 AM
  #116
just unhook the fuel lines, the injectors will just come out with the fuel rail. you don't have to take out the injectors unless its to put them into the new fuel rail.
Old Mar 3, 2009 | 02:43 PM
  #117
jaybdaboat's Avatar
ok i went to take off the 5 bolts and there rusted shut, and they stripped all the threads on my socket wrench, so now i have no tools and already bought the part, so i guess early in the morning imma be at autozone trying to fix my car with thier loaner parts haha
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
