anyone interested in a block, crank, and ported heads?
Old Dec 15, 2009 | 07:54 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Hope its ok to post this here...figured it'd get better attention here than in the classified section. I pulled my highly modded 3.1 out of my car due to a piston problem. I installed a 3.4 in it. I have the motor that came out if anyone wants parts. The block is embossed 2.8 on the side but, same thing. It does have the 3.1L stroke crank! The block is bored .75mm (or +.0295") oversize. All of the cylinders measure good! These are some of the parts that finally got me into the 14s in the quarter mile, n/a. The block is 100% bare right now with the exception of the oil filter adapter (and main caps). The main bearings and cam bearings should be replaced. I can probably put some new cam bearings in it if someone is interested. The heads have the 1.72"/1.42" valves, 3 angle valve job, and "z28" springs. They were heavily ported and polished (ex. side polished) a few years ago. The vane is still in the intake port but it is modified. I have not touched the heads since they came off of the car. I can clean them and do a valve job and check the springs if anyone is interested. If I go through all of that, I'd like to get a little more for them. So, throw me some offers if you want some good parts! Camshaft is no good so its not for sale. One piston is bad so I'm not selling them. The rods can be made available, though. Also, the flexplate is still bolted to the crank, currently.
I have stock valve covers and lots of bolts and stuff off of the 3.4/3.1. If you need anything, let me know...its cheap. If anyone wants to timing cover off of the 3.4 with the crank trigger, let me know! I don't know the condition of the sensor other than, its there.
Post here or PM me if you want anything!!
Old Dec 18, 2009 | 03:50 PM
Car: 91 Camaro
Re: anyone interested in a block, crank, and ported heads?
wow. I figured there'd be more interest in this stuff. Here's kind of what I had in mind...
block $50
block and crank (and flexplate ($100)
heads $125 as the came off the car.
$225 and I'll clean them, grind the valves, fresh 3 angle on seat, and check all of the springs and re-assemble.
(I have one person potentially interested in the heads, already)
I might be interested in some parts trades (aftermarket stuff - steering, suspension, tires, brakes,...)
Old Dec 18, 2009 | 06:41 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
I'd love to take the heads, but... a week before Christmas?
Old Dec 18, 2009 | 07:33 PM
Car: 91 Camaro
a week before Christmas...perfect timing! right? lol. Let me see if this other person wants them or not.
Old Dec 20, 2009 | 01:29 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
I am interested in the heads too... let me know what the other guy says.
Old Jan 6, 2010 | 04:33 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Crank trigger is external right?, ie. outside on the harmonic balancer or crank pulley? (forgive me I know nothing about the 3.4 RWD engines). If so, then name your price for crank trigger and timing cover....I'm one of those unlucky SOBs that wasn't blessed with DIS ignition and am building a hybrid XD, these days I actually know wtf a reluctor wheel is....I've come a long way, and I dug up an old post now that I can understand it, the timing cover and trigger you have seem to be exactly what I need...
Old Jan 6, 2010 | 05:02 PM
Car: 91 Camaro
sending a PM...
So far I still have everything! I've seen a little interest in the heads but no body has come through with money, yet. 3rd gen RS has dibs on the timing cover from the 3.4.
I know somebody has to want this stuff! I don't think I'm asking a lot for anything but, make me some offers!
Old Jan 22, 2010 | 09:46 PM
Car: 91 Camaro
timing cover, balancer, and oil pump drive are gone. everything else is still here, unfortunately.
Old Jan 23, 2010 | 11:58 AM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
I would love those heads...unfortunately I don't have the funds for it now.
Old Jan 24, 2010 | 11:47 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Is the crank still in relatively good shape, and does it have the DIS notches? I've heard that some 3.1 cranks do have the notches in the RWD application... And no, I don't need the flexplate (I have a 5-speed, and my flexplate from when I did the trans swap is waiting to be recycled).
Old Jan 25, 2010 | 08:46 PM
Car: 91 Camaro
It does have the notches and it is in good shape. i can get pics if you'd like.
Old Jan 26, 2010 | 04:10 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Just needed to know if it had been damaged because of rust or anything and if it had the notches. How much?
Old Jan 26, 2010 | 04:57 PM
Car: 91 Camaro
Nope, no damage of any sort. I have ground down the rough casting lines on it, too. I'd like $50 plus shipping. send me your zip and I'll try to figure up shipping.
Old Jan 26, 2010 | 05:59 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Shipping's going to be a pain to the 14482 zip... I know those cranks aren't light by any means.
Old Jan 28, 2010 | 08:14 PM
Car: 91 Camaro
Hey, just got a chance to weigh the crank and stuff... Looks like it'd be about $50 to ship it to you via UPS. I'd build a wooden box to put it in. (and, put insurance on it! especially considering a recent problem with shipping via USPS)
Old Jan 28, 2010 | 08:20 PM
Engine: 2.7L V6
Axle/Gears: 4.41
OWCH! If nobody takes it in the next couple of weeks, I guess I'll have to use some of the tax return for it... Either that or get some stuff to the scrap yard (which is nearly impossible because the closest one is on a back road which is terrible in the snow).
Old Jan 28, 2010 | 08:38 PM
Car: 91 Camaro
Just let me know if you decide you want it. I'll tell you if its still here (from the looks of things, it will be).
You guys are making me think about bolting these ported heads on my 3.4!! I really don't need to do that! lol
Jake_92RS
Jan 28, 2020 10:37 PM
MoJoe
Sep 24, 2015 09:12 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
