charcoal cannister problem HELP!!!!!!
Old Jul 13, 2010 | 07:24 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
My charcoal cannister is leaking fuel from the bottom, there isnt anything there but a filter looking thing!! HELP IM LOSING FUEL!!!, also if it helps i just put on new fuel lines and put in a new pump!!
Old Jul 13, 2010 | 10:54 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: charcoal cannister problem HELP!!!!!!
hi, is the car running ok ? the cannisters do get old and perished, took me a while to work out why i was doing just 10mpg, same prob as you. i have removed mine and blocked the pipe fom the tank. not sure if you will get away with that where you are, but basically you need a new one !
Old Jul 13, 2010 | 11:33 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Seems to me like something must be hooked up wrong ,especially since it just got a new fuel pump.
Old Jul 14, 2010 | 12:08 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
you must of crossed up a line, only vapor should get up there unless the tank is over full.
Old Jul 14, 2010 | 12:12 AM
Engine: L31 350
i only put $10 in the tank
Engine: L31 350
Car isnt running , im trying to get it to run
Old Jul 14, 2010 | 01:35 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Id say the return line n vent line got mixed up, the return line will siphone gas from the tank, I know when doing my SFC I broke it and it would not stop coming out. Plus those 2 lines are the same size.
Old Jul 14, 2010 | 02:54 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Read your post in the Tech forum, and several things come to mind:
1. If they aren't crumbling to pieces, PUT THE HARD LINES BACK IN!!! This is a SAFETY issue, and could cause you to fail inspection if the guy at the shop wants to be a real jerk.
2. The EVAP line comes from the passenger's side and crosses over to the driver's side at some point (have to look it up). That's how you can tell which one is which. And it also doesn't have the screw fitting on the end for the pressurized fuel fitting at the engine.
3. You'll want to go to a junkyard and get another can... Yours is now junk. They don't like being pumped full of gas.
4. The 4th line coming off of the fuel tank runs to the white pressure control valve by the driver's side rear wheel.
5. The brake lines will be covered in a spring-like material. Don't mix those up with anything (not that you really can as they are 3/16"), and DON'T use rubber hose on them or you won't be able to stop.
Old Jul 14, 2010 | 06:02 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Long as its fuel injection rated hose it don't matter if its rubber.
AZ sells the goodyear brand rubber fuel injection hose, stamped right on it.
Old Jul 14, 2010 | 06:36 PM
Engine: 2.7L V6
Axle/Gears: 4.41
I know... I bought six feet of it to use as transmission cooler hose on my sister's car when I redid the rusty cooler lines last year... Cost me $20+ for nothing (bought the wrong size hose and the car ended up getting sold as scrap for $150 anyways).
One rock hits that crap, and there's a fuel leak... As was said in the post in the Tech/General forum. Steel lines won't do that unless they're seriously rusty. Also, the rubber hose won't fit in the factory brackets, so I'd guess he used zip ties (another not good).
Old Jul 14, 2010 | 06:43 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I can't see a rock hitting the hose and doing anything, he would have to be off roading and draggin the bottom on a rock and then it would take allot to work its way through, and a steel line would get dented shut with the same pressure needed.
Its not some paper thin hose that a pebble on the freeway is gonna jump up into and split it wide open.......
Old Jul 14, 2010 | 10:28 PM
Engine: L31 350
Well if you remember i posted on here that the guy i had doing my fuel pump cut my lines at the pump in my doner car so i had to use rubber, iv already planned on getting another can to replace this one so were good, also my brake lines are there, i had 4 lines coming off the pump but i know what it is on from your 4. post.
Engine: L31 350
also, could this be why my car still isnt starting? cause the engine isnt getting gas?
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
TBRays98
Sep 6, 2015 05:05 PM
andy74
Sep 3, 2015 08:41 AM
