Gutted airbox where do i put the sensor?
Old Oct 24, 2000 | 03:02 PM
Dellz's Avatar
i took out my air box houseing and bolted in just the filter.. where should i put the sensor i was thinking about drilling a whole into the plastic and putting it there or can i just let it dangle?.. is there any draw backs to removing the hoseing? to the airbox?
Old Oct 24, 2000 | 03:04 PM
3.1 firebird's Avatar
you could drill a hole in the plastic. I;ve also been told you can let it dangle in an area where cool air is to trick the computer into adding more fuel to the mixture.
Old Oct 24, 2000 | 03:08 PM
Dellz's Avatar
Imagine adding a little fan infont of the sensor would that be any good .. like a processor cooling fan?
Old Oct 24, 2000 | 07:01 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
im kinda confused how u guys are gutting the airboxes and bolting the filters on..? are u just buying tpi clamp on k&N's or..?
88 Firebird 2.8
MODS (either coming or on):
Flowmaster Cat Back, Random Technologies Cat, 3" intermediate pipe, Accel 8.8 wires, MSD Coil, MSD Ignition Module,MSD 6a, B&M Shifter, Transgo Shift Kit, Cold Air Induction, NEXT MOD: 5 speed...(torque convertor going so 5 speed a better idea) ..Then peeling and cracking paint..
Old Oct 24, 2000 | 07:20 PM
Monkie's Avatar
Ive done this too and Im wondering which would be better...drilling the hole in the air tube thing and the putting the sensor in the hole or just letting it dangle by the filter????????? Thanks!
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
Old Oct 24, 2000 | 11:42 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
When i get a chance im gonna make mine longer and put it were it will be hitting cold air so it will put more fuel in my engine.
Old Oct 25, 2000 | 12:46 AM
voltran's Avatar
Instead of removing the sensor to a colder place to trick the computer, just put a 4.7K resistor between the wires. By doing that the comp. will read the air temp. as 32 degrees. ( If I'm not mistaken )
Old Oct 25, 2000 | 08:59 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
As posted on your other thread to this question...
On the LS1 engines you can put a 4.7 ohm resistor between the terminals of the sensor.
This gives the ECM the info that the air charge is colder than it actually is.
This allows the ECM to give a little more fuel/timing curve.
I personally don't think this mod is worth anything noticeable as far as performance goes. Some people say it is, I did it and took it back out. To each his/her own.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Jeremys87
Jul 14, 2022 09:08 PM
squiggy2
Aug 9, 2015 09:30 PM
