Engine temperature gauge is pinged all the way up,how do I fix?
Old Apr 2, 2001 | 12:42 PM
RS'er's Avatar
I have a feeling that my sender unit is not working right or grounded somehow. Where is the sensor at so I can fix it?
I'm the proud owner of an '89 Camaro RS w/ 70k miles and a 5 spd manual.
"CAMARO:
The only thing close to it is its shadow."
Old Apr 2, 2001 | 01:11 PM
HIX5000's Avatar
Does the gauge stay pegged out even if you turn the car off? If so it's probably the guage.
Old Apr 2, 2001 | 01:19 PM
sgtpanther's Avatar
Mine is doing the same thing...but it is only pegged once the car is started. And i already replace the coolant temperature sensor...behind the AC.
Sgt Panther
89 Firebird..2.8/3.4 conversion
Old Apr 2, 2001 | 01:41 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Does this have anything to do with that possible head gasket leak of yours?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Apr 2, 2001 | 02:21 PM
RS'er's Avatar
Stays pinged all the time,never ever seen it move.
Old Apr 3, 2001 | 06:33 PM
KED85's Avatar
You have an open circuit somewhere. That's why it's pegged. The sensor acts as a buffer to make gauge operate properly.
CHECK YOUR WIRES TO THE SENSOR. MAYBE YOU JUST NEED NEW CONNECTION ON END!!
YOU TOO CHAD!!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Apr 3, 2001 | 10:12 PM
RS'er's Avatar
Again,WHERE is the sensor???
"CAMARO:
Old Apr 3, 2001 | 11:26 PM
HIX5000's Avatar
The sensor is in the drivers side head, behind the a/c compressor. It has two wires going to it.
Old Apr 4, 2001 | 07:58 AM
sgtpanther's Avatar
Thank You Karl!!!
Sgt Panther
Old Apr 4, 2001 | 09:08 AM
RS'er's Avatar
<font face="Verdana, Arial" size="2">Originally posted by HIX5000:
The sensor is in the drivers side head, behind the a/c compressor. It has two wires going to it. </font>
Umm,hehe,My car doesnt have A/C...So where could I have a new description?
Old Apr 4, 2001 | 09:45 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Two wires...? I thought it only had one wire. At least, my '86 did, and my friend's '89 does.
Old Apr 4, 2001 | 09:50 AM
RenoLB8's Avatar
One wire is on the passenger head for the fan switch. Two wires, I believe, is the driver's side head for the actual temp gauge, cars with gauge package only.
Does this help TomP?
-Reno
Old Apr 4, 2001 | 11:39 AM
Kevin S's Avatar
Temp guage sensor is on the driver side head on front corner.It has a one wire connector that slides off and on.
The fan switch is on passenger head,near fire wall.It also has a one wire connector but it snaps on and off.
It sounds to me the wire for your guage has grounded out.
The only way you can fix this is to trace the wire back to the instr cluster.Once you have traced this wire into the car,use a trouble light or a muti-tester to check if it is grounded.If the wire is fine replace the sensor.If not that then replace the guage.If it still doesn't work, then...I have no clue
Since my dragon pic won't work I'll have to live with this...
Kevin S
89 RS w/2.9
modded some but not heavily
[This message has been edited by Kevin S (edited April 04, 2001).]
Old Apr 5, 2001 | 12:46 PM
HIX5000's Avatar
<font face="Verdana, Arial" size="2">Originally posted by TomP:
</font>
Thats strange mine has two wires. One green one black.
Old Apr 5, 2001 | 11:32 PM
KED85's Avatar
PERHAPS, that's the trouble, it jerryrigged!
It really could be the answer.
Chat Soon,
KED85
Karl
Old Apr 6, 2001 | 11:05 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hehe, lets pull out the years and figure this out! This would be great for my "years different" info! Thanks in advance!
My '86 2.8 (with idiot lights):
Fan Switch (rear passenger head): One wire
Dash Warning Light sender (front driver's head): One wire (green)
My friend's 89 2.8 Camaro (with gauges):
Dash's Gauge Sensor (front driver's head): One wire
Post your years and sensors guys, lets get this cleared up! Keep in mind there are two sensors on the intake manifold, each with two wires. One's for the computer, it's the CTS, one's for the cold start injector (85-89).
Old Apr 6, 2001 | 03:27 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
ok,
1990 3.1L:
DRIVER'S SIDE HEAD(front): gauge sensor-1 green wire.
INTAKE MANIFOLD: cts- 1 black wire, 1 yellow wire.
PASSENGER SIDE HEAD: i dunno, too lazy to look.
Dan
1990 3.1L RS
80 Series Flowmaster
It's fast(er than a 3 cyl metro)
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Aug 17, 2015 02:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
