V6 Cam
Old May 1, 2001 | 06:33 AM
Mach5's Avatar
V6 Cam
I am planning on doing a complete rebuild and I want to know what cam I should use. I have an 82 with the carburator. I will be running a 700r4 and a HEI ignigtion. THe heads will be milled and ported and polished. I will run my compression around 9.5 to 1. Thank for any help
82 Firebird with a 2.8
87 Chevy K20 4x4 TBI pickup
71 Olds Cutlass S My ongoing project. Olds
350 with a th350
Old May 1, 2001 | 08:31 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Think about picking up a set of heads from an '85-up multiport injected V6. In '85, the heads got bigger valves. (In fact in '85, because of that and the fuel injection system, the 2.8 became the "High Output" 2.8. It lost that HO designation in '86, I guess because it wasn't "new" anymore.) Those heads would help airflow by themselves; if you do a port job on 'em, you're really getting some air inside!
The '82 also got a mild cam, compared to the '85-up 2.8 multiport. A stock 85-up cam would wake your engine up by itself. Crane has a few cams, as does http://www.spoperformanceparts.com and http://www.pawinc.com . The problem is, NOBODY's got a 2.8 cam that's APPROVED as 50-state-legal for emissions. Cams might exist that do pass the emissions levels, but none are certified to do so. I don't know if your part of the world has adopted the dyno emissions test like my NJ has; so this might be something to think about. Past that, I can't recommend a cam... for fuel injection, yeah, but I don't know about for carb. PAW has a ton of cams for carb'd 2.8's, each with different specs.. I think their "own" home-brand has 5 or 6.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 1, 2001 | 09:01 AM
Mach5's Avatar
Thanks. We do have the dyno emissions tests here in Connecticut and the people that run them know nothing about cars. I heard that aluminum heads would not fit the longitudal mount engines. Is this true?
350 with a th350
Old May 1, 2001 | 11:13 AM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
That is correct...the FWD heads will not fit the longitudinal-mounted 60 degree V6s.
On a side note, doesn't CT have some sort of cut off point for emissions testing? I know in MA, '84 and older don't need to pass. I believe CT has the same smog laws as MA!!
Jason E
'89 Camaro RS 2.8
Medium Grey Metallic
2.8, A4, T-tops, 90k miles
'97 Z28 w/30th Anniversary package
LT1 (obviously), 6 speed, t-tops
White with orange stripes, killer system, 41k miles
Speed Kills...Wanna live forever? Drive a Ford.
Long Live #3...
Old May 1, 2001 | 12:33 PM
Mach5's Avatar
The cut off for emissions in CT is 25 years or 1976. I don't go there anyway because the people are so incompetent. Do they make aluminum heads for the longitudal mount engines?
Old May 1, 2001 | 02:58 PM
KED85's Avatar
NO FWD ALUMINUM HEADS WILL WORK FOR THE F-BODY APPLICATION.
NONE!
How to get around all of this...
Go get a 3.4 engine from a yard & install it!
Shame you have a carb, tho.
The MPFI really makes this engine a road racing stunner. Ask the Porsche I kept up with (faster than posted limit).
Of course he won, it was a safe situation.
OR go get a 1985 car to play with. And slip in the 3.4 block!
You would love the difference!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old May 1, 2001 | 03:40 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I like carbs no computers and you can adjust them to how you want it and you can swap them out and have fun with them.
Old May 1, 2001 | 04:04 PM
Ovrclck350's Avatar
<font face="Verdana, Arial" size="2">Originally posted by FAST RS:
I like carbs no computers and you can adjust them to how you want it and you can swap them out and have fun with them. </font>
Kinda like girlfriends?
Old May 1, 2001 | 04:21 PM
Mach5's Avatar
I wish my girlfreind had a carberator. That way I could Make the throttle body smaller for increased velocity (if you know what I mean).
350 with a th350
Old May 1, 2001 | 05:16 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
haha...geez some ppl in here need to get themeselves some..
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
" I'd rather run last in a full out race, than to NOT run at all ".
Old May 1, 2001 | 05:47 PM
Ovrclck350's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Mach5:
</font>
You need the throttle body smaller to compensate for a smaller injector? J/k.
Old May 1, 2001 | 06:13 PM
FAST RS's Avatar
Just make sure she dosent flood out at WOT lol did i say she wait i mean the car my bad
Old May 2, 2001 | 10:29 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Just so I'm not called a BS'er (again)... if you look at the Summit Catalog, there's a 50-state-legal notation for the Crane Cams. That doesn't cover the 2.8 cams. The CARB EO #'s listed are for the v8 camshafts. You can use this website to look up the CARB Executive Order #'s: http://www.arb.ca.gov/msprog/aftermk...es/devices.htm
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
