car stumbles during first to second shift
Old May 8, 2001 | 02:44 PM
Brads RS's Avatar
This is kinda hard to explain but here goes, Usually after the car has sat for a good 4 to 5 hours i can start the car and it starts fine but when i take off and it shifts from 1st to 2nd it stumbles really bad almost to the point of the engine dieing. Now after that it wont do it untill it sets for a while. Any ideas to whats causing this would be great
1992 RS 3.1
Flowmaster exhaust
Hypertech power chip
180 thermo
AC delco rapid fire plugs
8 MM Accel Plug wires
Crane cams Fireball Coil
K&N filter
3.73 posi (not installed yet)
[This message has been edited by Brads RS (edited May 08, 2001).]
Old May 9, 2001 | 08:52 AM
KED85's Avatar
Put back in the stck chip & try it again.
I'll bet it's the chip.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old May 9, 2001 | 11:30 AM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
check your vacuum lines
Old May 9, 2001 | 04:24 PM
Brads RS's Avatar
I checked all the vaccum lines and put the stock chip back in and it still does it . I was wonderin if the pickup coil might cause that if it was goin bad?
1992 RS
Flowmaster exhaust
180 thermo
K&N filter
Old May 9, 2001 | 04:39 PM
KED85's Avatar
Nah, coil goes bad, you'll know!!
Could be exhaust?
Is it extreme high RPMS the power drop happens?
DID YOU RECENTLY CHANGE THE FUEL FILTER?? OR FUEL LINE HOSES???
Chat Soon,
KED85
Karl
Old May 9, 2001 | 05:11 PM
Brads RS's Avatar
It Drops at low RPMs and its about time to change the fuel filter (About 7 months on this one)
Old May 10, 2001 | 03:52 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
When's the last time it got the tuneup parts? (plugs/cap/rotor/timing/tb clean/etc?)
Old May 10, 2001 | 11:49 PM
KED85's Avatar
Don't laugh.
I think the fuel filter was recently changed.
I'll bet they used the wrong fuel line hose.
Check it out.
Fuel filters last a long time.
Once had a car.
Fuel injected Opel Wagon, 1975 model.
It was a great car!
BUT, one time I changed the fule filter and used wrong hose.
It was collasping at high suction time.
Caused the car to not accelerate.
Ideled great.
Zoomed RPMS great, at rest.
Driving, couldn't get over 30 mph!
Look.
Chat Soon,
KED85
Karl
Azrael91966669
25
Jun 20, 2017 04:04 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
squiggy2
Aug 9, 2015 09:30 PM
gwade12
Aug 8, 2015 08:17 AM
