2.8 ?
Old Sep 5, 2011 | 12:27 PM
GCM-Daniel's Avatar
Car: 92 Camaro RS
Engine: 350 :)
Transmission: 5 Speed
Axle/Gears: 3.73 posi 10 bolt
2.8 ?
Ok, 2.8, 5 speed.
Idles around 1250 but when running 60 turning 4500. It has the stock 3.42 rearend in it. Anyone know WHY this is?? Help greatly appreciated
Old Sep 5, 2011 | 12:31 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: 2.8 ?
First guess... speedometer is reading high. I had one that read the exact same thing. As they get old, they start reading high
Old Sep 5, 2011 | 12:39 PM
GCM-Daniel's Avatar
Car: 92 Camaro RS
Engine: 350 :)
Re: 2.8 ?
This was my thought at first. so my friend drove beside me to test it and it was dead on. And i took a aftermarket tach from another buddy and it was reading the same 4500 at 60
Old Sep 5, 2011 | 01:07 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Re: 2.8 ?
Is it shifting into higher gears? Or are you going 60mph in secong gear?
Old Sep 5, 2011 | 01:21 PM
GCM-Daniel's Avatar
Car: 92 Camaro RS
Engine: 350 :)
Re: 2.8 ?
Its a 5 speed.
Old Sep 5, 2011 | 01:50 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Re: 2.8 ?
What gear are you in? Is the clutch slipping?
Old Sep 5, 2011 | 01:53 PM
GCM-Daniel's Avatar
Car: 92 Camaro RS
Engine: 350 :)
Re: 2.8 ?
3.42, and no the clutch works as it
should
Old Sep 5, 2011 | 02:35 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: 2.8 ?
i imagine your tach is bad...not uncommon, does it sound like its actually reving that high?
Old Sep 5, 2011 | 04:07 PM
GCM-Daniel's Avatar
Car: 92 Camaro RS
Engine: 350 :)
Re: 2.8 ?
im not sure what a 2.8 should sound like at that high
Old Sep 5, 2011 | 05:39 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 2.8 ?
the tach is broke or your not shifting the gear right and aren't in 5th.
Old Sep 5, 2011 | 06:12 PM
58mark's Avatar
Re: 2.8 ?
I guess I could go take a short video of my car revving to 2500, which I think it what it runs at highway speeds (been a while since I drove it) and then I could rev up to 4500. you could compare the video to what you are experiencing
Old Sep 12, 2011 | 09:01 AM
MaroWhite&black's Avatar
Car: 89 Camaro RS, 99 2500HD ,03 escalad
Engine: 2.8l V6 :(
Transmission: M4 auto trans with B&M shift Kit
Axle/Gears: 3.42 std gear ratio
Re: 2.8 ?
Originally Posted by GCM-Daniel
Its a 5 speed.
Well what gear are you in? if its already in 5th your clutch is slipping and you just dont know it. or does your car take a while to rev to high RPM'S when in nuetral? when in nuetral rev your car the faster it gets to the red line the better. the faster it drops in RPM's the better. so when you rev it as soon as it gets to the red line completely drop the gas pedal and see how fast it goes down. if it takes 5-7 seconds or more, your motor is WORE OUT. Thats the best way to test a motor in a car when buying one also. You want your RPM'
s to be redlin'ing from idle in about 2 seconds or less. and you want it to drop from redline to idle in 2-3 seconds. Hope this helped. LMK.
Old Sep 13, 2011 | 07:15 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: 2.8 ?
what size tires are on the rear of the car?
Old Sep 16, 2011 | 09:29 AM
GCM-Daniel's Avatar
Car: 92 Camaro RS
Engine: 350 :)
Re: 2.8 ?
215 tire size and found out it was the tach. thanks guys
Old Sep 16, 2011 | 10:56 AM
Engine: 2.8l V6 :(
Re: 2.8 ?
I was running 215's on my 89 RS and i switched to 205's on the back and 195's on the front and my car runs 3mph FASTER now.??????
Old Sep 16, 2011 | 01:50 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 2.8 ?
This will help caculate tire changes.
http://www.miata.net/garage/tirecalcold.html
IM running 225/60s rear, 205/70s front.
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
