V6 Troubles
Old May 11, 2012 | 06:40 PM
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
V6 Troubles
Couple of problems I am having, my car randomly takes longer to start at times. I always prime the fuel pump by leaving it in acc. until I hear it stop then crank it over. Sometimes when it's cold it starts right away, other times it doesn't and requires a second crank.
Another problem I am having is my transmission (automatic) is leaking transmission fluid. The seal behind the speedometer cable is leaking I believe, where can I find a replacement seal?
Old May 15, 2012 | 12:35 PM
ex-x-fire's Avatar
Re: V6 Troubles
First, hook up a fuel pressure gauge, the running pressure should be 36-42 psi & it should hold pressure after the engine is shut off. If it doesn't then you have a bleed down problem, most likely the regulator or check valve in the pump.
Try rock auto for the seal, a tranny shop might have one too.
Old May 15, 2012 | 02:39 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: V6 Troubles
For me the first symptom turned out to be a leaky fuel pressure regulator diaphragm.
Old May 15, 2012 | 05:08 PM
Axle/Gears: 10 Bolt
Re: V6 Troubles
You just hook up a fuel pressure gauge to the nipple on the fuel rail then put everything back together?
My freaking rear cam cover is leaking...ugh...so much work for so little miles.
Old May 15, 2012 | 05:43 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: V6 Troubles
You don't need to dismantle anything to hook up the pressure gauge. Pull the vac line off the FPR and smell for gas. And when were the injectors last checked?
Old May 15, 2012 | 05:45 PM
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
Re: V6 Troubles
about the oil, check the distributor gasket, as i was told, i looked more into it and that was where my problem was with most oil, not 100% sure until i actually get my baby running again (changing head gaskets and p&p)
Old May 15, 2012 | 06:02 PM
Axle/Gears: 10 Bolt
Re: V6 Troubles
I think I fixed the transmission speedometer leak for now or forever who knows. I just took it off and flipped the o-ring around lol.
I don't know the condition of the injectors, car has only 80K on it with annual maintenance.
The fuel nipple is under the plenum so it would have to come off wouldnt it? To check fuel pressure at least..Raining right now so can't do anything.
The distributor is new and so is that o-ring would it really still leak...I took off the transmission inspection plate, rear main seal was dry, right above that the little cover plate seemed to have oil on it.
Old May 15, 2012 | 06:19 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: V6 Troubles
Not sure on the 2.8 if the fuel valve is accessible without removing the plenum. I'd be surprised if you do. However, you should at least check the resistance of the injectors which does require removing the plenum. Should be 12-13 ohms or so and all very close in value.
Old May 15, 2012 | 06:24 PM
Axle/Gears: 10 Bolt
Re: V6 Troubles
Ok, so disconnect the injector connectors and hook them up to a multimeter and check for an ohms reading. I am going to be doing my valve seals soon so I will check that.
Yes, the fuel nipple is under the plenum. So I believe I have to remove it, remove the fuel cap install my gauge and run it out the back then hook my plenum back up to run the car with the guage hooked up.
Anyone know what color the bosch injectors are compared to the multec injectors? I want to know what kind of injectors are in this puppy.
Old May 16, 2012 | 08:14 PM
Axle/Gears: 10 Bolt
Re: V6 Troubles
Injectors are all 16.7 and 16.8 ohms, good?
How can I tell which brand I have? All that is on them is numbers.
Old May 17, 2012 | 04:40 AM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Re: V6 Troubles
just get some new ones, im selling some *LIKE NEW* injectors i bought, but im turboing so ill need 28lb instead of 17 lb injectors, you interestes?
mrbird
Oct 20, 2015 03:43 AM
Lmancha96
Sep 25, 2015 08:11 PM
HikoriYami
Sep 21, 2015 07:11 PM
BWilcox
Sep 20, 2015 12:19 PM
eduardosac
Sep 16, 2015 02:18 PM
