need help with 3.4L
Old Sep 8, 2012 | 06:16 PM
batsibf's Avatar
Car: 1986 Firebird
Engine: 3.4L Swap is done
Axle/Gears: Stock
need help with 3.4L
hey all, I got my swap done and everything was going great but I had a water line bust when i was test driving it checking things out, I got her towed home now i have water vapor coming out at idle and blue smoke when accelerating. now I still have my 2.8 engine, and I'm thinking I have a cracked head on the 3.4.
how close are the 2.8 heads to the 3.4 heads and if I put the 2.8 heads on the 3.4 would I lose anything? basicly what is the pro and cons of using the 2.8 heads on a 3.4?
Old Sep 8, 2012 | 06:50 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: need help with 3.4L
exactly the same heads. Put them on as theres no difference. Unless you have a pre 1984 engine (carbed 2.8L IIRC)
Old Sep 8, 2012 | 07:44 PM
batsibf's Avatar
Car: 1986 Firebird
Axle/Gears: Stock
cool thanks, I just pulled the plugs and I got water on #3 I'm hoping for a blown head gasket but prepering for the worst
Old Sep 8, 2012 | 07:55 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Drain out your oil in that engine asap just in case you have coolent in there. Check the oil and see if its mixed... which i hope its not, but if so you can still be ok. I had that happend about 1 year ago and didnt have any immediate issues once i put it back together.
Old Sep 9, 2012 | 02:51 AM
batsibf's Avatar
Car: 1986 Firebird
Axle/Gears: Stock
Oil is fine, it still looks like it just came out of the bottle, but once I put it back together it's getting an oil change any way. Hoppfuly I will have her running by the end of the week
Old Sep 10, 2012 | 03:38 AM
batsibf's Avatar
Car: 1986 Firebird
Axle/Gears: Stock
Well today found water in the oil, that oil is gone. Got the head off, can't see any cracks, the block is holding water for about 12 hours now(filled the water jack to see if it would leach in like it did when I had it setting), head gasket dose not have anything standing out as an issue. I'll try to post some pic later. Found oil and water in the intake to cylinder #3, all the other cylinder are clear. Is there anything else I can do besides putting it back together, or taking the heads to a shop? I'm planning to make sure the heads are still true this after noon.
Old Sep 10, 2012 | 04:31 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Just take the head to a shop and make sure its not warped. Buy new head bolts, gaskets, toss it back together and do a compression test before you put the rest of the engine back together.
Take some picks of the cyliner, heads, and post them up if you can.
Old Sep 10, 2012 | 07:25 AM
batsibf's Avatar
Car: 1986 Firebird
Axle/Gears: Stock
I'm going to check them this after noon, and get the pic's. I just want to do as much before hand so I don't get a repeat
Old Sep 10, 2012 | 02:59 PM
batsibf's Avatar
Car: 1986 Firebird
Axle/Gears: Stock
ok just checked the head and block and both come out true, here are the pic's I promised
Attached Thumbnails need help with 3.4L-img_5275mod.jpg   need help with 3.4L-img_5276mod.jpg   need help with 3.4L-img_5277mod.jpg
Old Sep 10, 2012 | 05:36 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Head gasket looks a little iffy, but Id still get those heads checked by a shop just to make sure there not warped.
Is it only the one side you had a problem with??? Which side is that driverside?? #6? Closest to the firewall?
Old Sep 10, 2012 | 06:05 PM
batsibf's Avatar
Car: 1986 Firebird
Axle/Gears: Stock
it was #3 (center passanger side) I was not going to reuse the gasket, I am actualy going to pull the other side of to and just put new gaskets and bolts all around just so i don't have this again
Old Sep 10, 2012 | 06:10 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Yea get some new gaskets. Also get some new head bolts for piece of mine. There about 25 bucks at autozone. Felpro ones.
Old Sep 23, 2012 | 12:14 PM
batsibf's Avatar
Car: 1986 Firebird
Axle/Gears: Stock
Hey thanks for the help, everything is back together no smoke, had a little water vapor when first started but heated up and went away. Thanks again
Old Sep 23, 2012 | 02:25 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Good stuff, glad to see it worked out for ya!
Keoki_Firebird89
Mar 10, 2002 11:50 AM
Keoki_Firebird89
Feb 17, 2002 12:06 PM
Drew
Dec 31, 2001 01:34 PM
Drew
Sep 4, 2001 11:49 PM
Mike Harvey
Feb 2, 2001 06:42 PM
