changed plug wires now won't start......
Old Sep 14, 2013 | 08:21 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
hey guys, i'm helping a friend with his v6 car and it's being a pain in the a$$. We just changed the wires on this damn thing and now it's acting like it's out of time. the ONLY thing changed was the wires since the plugs rotor and cap were brand new. I've checked the firing order 3 times and the damn thing just refuses to kick over. Any thoughts?
Old Sep 14, 2013 | 09:00 PM
Re: changed plug wires now won't start......
here's a video of what it's doing....
Old Sep 15, 2013 | 06:42 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Sure does sound like the timing is off.
123456 firing order with the #1 cylinder starting at 7pm looking at the dizzy from the front bumper? Going arround the dizzy 123456 clock wise from that 7pm starting point.
Passanger side cylinders from front(the bumper) to the fire wall... 135
Drivers side cylinders from the front(the bumper) to the fire wall... 246
It ran fine before you changed the wires? Check them over again but its strange that its doing that now if all you did was change the plug wires.....
Old Sep 15, 2013 | 11:51 AM
that's how we routed the wires, in correct order. We even put all the old stuff back on and tried it and it's still doing the same thing. We're completely stumped as of right no. I'm almost tempted to pull the distributor and reset the end back up to TDC to see if that will help.
Old Sep 15, 2013 | 12:42 PM
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
Where wires in correct order when you took them off, was dist off and they compensated by putting wires one step off?
Old Sep 15, 2013 | 02:51 PM
fasteddi's Avatar
Car: 1991 Camaro RS
I would take the cap off. Inspect it. Match up the dizzy and crank position to #1 tdc. Reset the timing to a base of 10* btdc with the ESC wire off at a normal idle rpm. Then hook the ESC wire back up, reset the ecm and start it up.
Also make sure you didnt mess with any of the wires on accident, such as the grounds on the rear of the passenger head, and also recheck the esc wire, and the wires from the coil to the dizzy and so on.....
Old Sep 15, 2013 | 10:05 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
make sure it doens't move, my dizzy would turn a hair on it own, run not at all or bad, bump it and runs great, hold down wasn't super tight anymore.
was a stumper
Old Sep 16, 2013 | 06:24 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Wrong firing order or #1 is not on the correct post, that would put the rest of the wires also on the wrong post.
Old Sep 16, 2013 | 07:20 PM
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
Sounds like its bucking from too much advance, and almost seems as if the plug wires need to be moved clockwise one post.
Old Sep 16, 2013 | 09:07 PM
well I guess it was figured out, the coil went bad. They got it fired up yesterday. thanks for the help guys.
eightsixseven
Dec 16, 2024 01:50 PM
Derick15
Sep 17, 2016 05:28 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
