one more 2.8 to 3.4 swap ques.
Old Jul 30, 2014 | 11:24 PM
Baxbird89's Avatar
Car: 1989 camero RS
Engine: 3.4L
Transmission: 700 R4
Axle/Gears: stock
I am attempting the 2.8 to 3.4 swap in my 1989 rs I have read up on it and believe I understand all involved. my question is can I use the 3.4 base intake ( with 2.8 middle and upper on top ) which doesn't have a spot in rear of base intake for cold start valve or in front for switch thus eliminating the cold start valve all together? while also plugging up the rear of fuel rail? will this work at all or not at all? I live in florida so cold temps will not be much of a issue? from what I understand it will just increase the cranking time till start ? any input on this would be soooo much appreciated thanks in advance
Old Jul 31, 2014 | 09:15 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: one more 2.8 to 3.4 swap ques.
Where at in Florida?
When doing the 2.8-3.4 swap you keep ALL of your 2.8 accessories, intake, manifolds, sensors, and the like. All you use from the 3.4 is the block and heads. The lower intake manifold is different on the 3.4. I'll have to find my comparison pictures from when I did the swap, but I'll post them when I find them.
Old Jul 31, 2014 | 07:34 PM
Baxbird89's Avatar
Car: 1989 camero RS
Engine: 3.4L
Axle/Gears: stock
St Petersburg/ Thanks for the reply I have both engines side by side haven't really tore into them yet I was just pondering some ideas lol I appreciate your expertise seeing that you have done this swap yourself. I might need to pick your brain a bit throughout this process if you don't mind seeing this is my first swap. But I think I got the jist of it thanks again for the reply
ohhhh yeah maybe someone can answer this for me as well during removing my 2.8 the two wires going into the cold start injector got pulled out ( connector at rear of base manifold ) one purple and one looks kinda yellowish or tan? which side of injector does the purple one go to? if looking at the engine from the front is it the left or right side? thanks again
Old Jul 31, 2014 | 10:35 PM
Car: 1989 Camaro RS
Engine: LH6
I'll check for you in the AM. If you need pictures of anything let me know.
Old Aug 1, 2014 | 06:01 AM
Baxbird89's Avatar
Car: 1989 camero RS
Engine: 3.4L
Axle/Gears: stock
cool thank u so much you are awesome, I plan on really starting on it this weekend and I got most of next week off work so I hope I can have it all back together by Thursday or fri :-) would u suggest doing a new timing chain? if so would I use a 3.4 timing chain?
Old Aug 1, 2014 | 01:18 PM
Car: 1989 Camaro RS
Engine: LH6
How many miles are on the motor? The chains are the same from 2.8-3.4
Old Aug 1, 2014 | 08:33 PM
Baxbird89's Avatar
Car: 1989 camero RS
Engine: 3.4L
Axle/Gears: stock
the 3.4 has 101k on it the guy I got it from just put a new crankshaft in it so he might have done the chain also Im not sure ill look at it tomorrow when I remove the cover. did u get a chance to look at those wires going to the cold start injector by any chance?
Old Aug 2, 2014 | 12:52 AM
Car: 1989 Camaro RS
Engine: LH6
I didn't today, but I need to fix my oil pan gasket tomorrow so I will check then.
Old Aug 2, 2014 | 09:14 AM
Baxbird89's Avatar
Car: 1989 camero RS
Engine: 3.4L
Axle/Gears: stock
cool thanks
Old Aug 7, 2014 | 02:00 PM
Car: 1989 Camaro RS
Engine: LH6
Hey bud, sorry I haven't gotten you the pics you need. I've been crazy sick this week. I'll try to get out tomorrow, I'm feeling better today.
Old Aug 7, 2014 | 02:20 PM
Baxbird89's Avatar
Car: 1989 camero RS
Engine: 3.4L
Axle/Gears: stock
its ok sorry to hear u r sick I hope u feel better I think I might have figured out the wires for the cold start thing but if u could send me a pic or just take a look at it and post your findings that would be great just so I know for sure. whenever u get a chance and r feeling better of course thanks again and hope u feel better soon
Cleotiz
Jan 6, 2018 08:56 PM
Digs_do_it89
Aug 30, 2015 10:24 AM
E Rod
Aug 28, 2015 05:17 AM
86Base
Aug 8, 2015 01:34 PM
92projectcamaro
Aug 6, 2015 01:20 PM
