Water pump removal?
Old Jul 26, 2015 | 12:22 AM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
Water pump removal?
Does anyone know what to use to remove a stripped Torx screw? I really need to remove a water pump to replace the seal???...I have one bolt to remove and need to get this done before Monday!!!
Thanx in advance*
Old Jul 26, 2015 | 09:13 PM
sheltonw3's Avatar
Engine: Classified
Re: Water pump removal?
Okay, got it figured out, gotta get a Irwin bit removal tool set*
Old Jul 27, 2015 | 12:20 AM
project89's Avatar
sometimes u can hammer in the next size up torx bit , if not ived used vise grips tograb the head of the bolt and break it loose.
final option is is to use a drill bit and drill the head of the torx bolt off and then use vice grips on it after u pull the water pump off
Old Jul 28, 2015 | 11:57 PM
AussiePr0nCar's Avatar
Car: 1991 Camaro RS, 1991 Firebird
Engine: None, 3.1l LH0 V6
Transmission: None, 700R4
Axle/Gears: 3.42 Open, 3.23 Open
For Torx screws, sometimes the bolts may not be so badly stripped that you can use an Allen key to get them out in my experience.
Old Jul 29, 2015 | 02:15 AM
bryan623's Avatar
Car: 89 GTA
Engine: 5.7 TPI
Hammer a cheap socket on to it and try to get it loose that way too. Those bolts aren't on too tight anyway. Spray some PB nut buster on it or some WD40 to help loosen it up.
Old Aug 1, 2015 | 06:00 PM
sheltonw3's Avatar
Engine: Classified
Having problems removing the Power steering to get to the bolt behind the power steering mount, did I miss something my Chiltons manual is not showing me too much*
Old Aug 1, 2015 | 08:10 PM
project89's Avatar
u talking about the bolt under the pulley? uneed a power steering pulley puller to take the pully off to get to it
Old Aug 1, 2015 | 08:32 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
98% sure my 86 has a hole in the PS pully.
Old Aug 1, 2015 | 10:05 PM
sheltonw3's Avatar
Engine: Classified
Great!...all out of money, I got 3 weeks of school left and no car to finish*...
I was told that there was only two bolt to remove to gain access to pull the water pump off?......It's already nearly 100 degree's outside., my brain is now fully cooked*
Old Aug 1, 2015 | 10:31 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
You should be able to "rent" a power steering pulley puller for free from most any auto parts store.
Did you check for the access hole that Gumby mentioned?
Old Aug 1, 2015 | 10:54 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
I've been able to use a wrench to get the bolt behind the power steering pump pulley. Do it last and you should be able to get it. It won't be easy, but it's usually doable.
Old Aug 2, 2015 | 04:47 PM
sheltonw3's Avatar
Engine: Classified
I just tried to remove the #6 bolt, but its a no go, it's in a tight spot, between the metal hose and motor mount*...my hand and fore arm are too big to allow me to get there, the only real way to remove this bolt is with a remote camera and monitor and impact wrench!
Water pump/Power steering assembly<br/>
Old Aug 2, 2015 | 06:01 PM
You shouldn't have to remove that bolt anyway, it just attaches the support bracket to the engine, removing the two nuts (#3) shoudl be all you need to do.
Old Aug 2, 2015 | 10:22 PM
sheltonw3's Avatar
Engine: Classified
It's not coming off!!!
Old Aug 2, 2015 | 10:45 PM
Then it may be time to throw in the towel and take it to a mechanic with the proper tools.
Old Aug 3, 2015 | 12:14 AM
sheltonw3's Avatar
Engine: Classified
Can't, no money, and I need my car now!!!!!!!!!!!
Old Aug 6, 2015 | 01:24 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Sorry I was thinking of my Buick, it has a hole for access [ they tended to use forthought allot more then other div's of GM ]
Old Aug 6, 2015 | 01:27 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
does it still run? let it get hot then try, let it get hot and smack it hard with hammer, get it hot then pour really cold water on the bolt, heat just the bolt head till smokin hot then touch candle to head or use oil, to wick in.... shock it to make it lets lose stuff.
Old Aug 8, 2015 | 08:10 AM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
Looking at your diagram, if you have all three number 9 bolts and the two number 3 nuts off, It will still be stuck. You must remove bolt number 6 and nut number 4 , as the pump must be removed up (vertical) and not out (horizontal). The aluminum bracket saddles the pump shaft behind the pulley, so you must remove the rear bracket, at least from the block side, so the p.s. pump studs wont hold you back.
That is, unless you can remove the studs from the back of the pump, then the bracket can stay on the block.
Best of luck. If you were closer I'd offer a hand
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
MoJoe
Sep 24, 2015 09:12 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
