MAF code 33 & 34.. what's the fix?
Old Mar 26, 2016 | 05:26 PM
SteelheadBen's Avatar
Car: 1988 Camaro RS
Engine: 2.8L v6
Transmission: 700r4 stock?
Axle/Gears: peg leg one tire fire
hello all, my camaro is running like garbage. idles high and stalls at lights. checked the codes and got codes 22, 33, & 34 relating to the maf sensor. what do I do to fix? I heard it can be anything from the sensor to the relays.
Old Mar 28, 2016 | 09:24 PM
Car: 1988 Camaro RS
Engine: 2.8L v6
Re: MAF code 33 & 34.. what's the fix?
case closed.. checked voltages and ground from cable.. all good power. so then I replaced actual MAF and works good now.
Old Mar 31, 2016 | 06:08 AM
ktthecarguy's Avatar
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Hi there,
I had the same, error code 34. replaced the MAF with a (supposedly) good one, still code 34. Replaced THAT with a MAF from Rock Auto, now it idles smooth, and no more code 34.
Old Apr 1, 2016 | 06:37 PM
Gfunkill's Avatar
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
ive never had a working MAF, just kinda "got by it"....don't ask.
Anyway, ktthecarguy, what MAF did you get from rockauto, I was looking at them today, and would like to get something dependable.
Old Apr 2, 2016 | 01:06 AM
On Probation
Hi Gfunkill,
I used the Walker 245-1001 MAF, and seems to be working fine.
Old Apr 2, 2016 | 08:51 AM
Gfunkill's Avatar
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
thanks
Old Apr 22, 2016 | 11:09 AM
Car: 1988 Camaro RS
Engine: 2.8L v6
autozone has the durlast MAF sensors, even though their cheap, they come with a 1 year warranty.. and mine works fine.
Old Jul 31, 2016 | 10:49 PM
Finally Got one's Avatar
Delete
Pbarnett98
Mar 8, 2016 11:01 PM
Whoboy580
Mar 4, 2016 07:10 PM
87-bird
Mar 4, 2016 05:04 PM
3gnation
Mar 3, 2016 10:11 PM
dmccain
Mar 3, 2016 07:06 AM
