Brass colored flakes in the engine oil of my 91' Firebird
Old 06-16-2018, 03:31 PM
Pupkin's Avatar
Hi,
today I changed the engine oil of my Firebird which has the 3.1 LH0 engine. I noticed that there were brass colored flakes in the engine oil.
I opened the oil filter but all was clean there.
What is wrong with the engine? Bearings? Which of them? Camshaft or crankshaft?
Thanks.
Old 06-18-2018, 02:44 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Brass colored flakes in the engine oil of my 91' Firebird
Thanks.
Bearings yes, no way to tell without taking it apart which ones though, most likely rod/mains
Old 06-21-2018, 12:11 PM
aycaramba's Avatar
Car: '1991 Pontiac Firebird
Engine: LH0 - V6 3.1
Transmission: TH700R4 automatic
Is it anyhow possible to replace the rod/mains without taking the entire engine out of the car?
Old 06-21-2018, 04:05 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Rods yes mains no. How much brass did you find, and do you have any knocking?
Old 06-21-2018, 07:55 PM
NoEmissions84TA's Avatar
Rods yes, mains yes. It's called a "roll" install, where you roll the main bearing in while turning the crankshaft.
I didn't say it was easy, but compared to removing the engine...........
Of course this assumes that the journals are in usable shape.
And with the main bearings, the grooved half goes to the block side.
Old 06-22-2018, 06:56 AM
aycaramba's Avatar
I've had the chance to do the roll-install on an inline-4 cylinder engine which was quite easy. Taking of the sump seems to be difficult because the sub-frame is in the way. (LH0 engine)
Old 06-25-2018, 10:39 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Just doing an oil pan gasket in the car was bad enough. I'd just pull the engine. You most likely have other gaskets and stuff that you'd want to replace anyway. If you've never pulled an engine it can sound intimidating, but it really isn't too bad.
Old 06-25-2018, 12:43 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Drive it till it dies and swap ina 3.4
Old 06-25-2018, 01:28 PM
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
I have a solid 3.1l in Michigan, where are you located? I'm just south of detroit. Has a delta 260 cam in it as well!
RS305
02-16-2008 02:00 PM
2QUIK4U
06-16-2006 11:35 AM
rmchugh
05-08-2006 04:28 PM
Blackroc86
09-19-2003 07:44 PM
redberlinetta86
05-04-2002 09:33 PM
Quick Reply: Brass colored flakes in the engine oil of my 91' Firebird
