Code 13 after Headers Install.
Old Apr 2, 2019 | 04:46 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
I have been getting a code 13 lately when in higher rpms. Have had my headers on for almost 5 months now. When my check engine light comes on it almost always goes out a few seconds later but sometimes it takes a bit longer. 10 15 seconds. How can I fix this? New o2 sensor? Or is there more to it.
Old Apr 2, 2019 | 05:05 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Code 13 after Headers Install.
http://www.chevythunder.com/o2_sensor_diagnostics.htm
Old Apr 2, 2019 | 08:19 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
I guess I could buy a new one if it's faulty. Has been on there for quite some time. I read on a thread something about a heated sensor but don't quite remember.
Old Apr 2, 2019 | 08:24 PM
Engine: Lb9
Transmission: M20
You can add a 3 wire delco Afs-74. With headers the o2 can cool off and not go into closed loop. This usually happens at idle though.
Old Apr 2, 2019 | 09:37 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Yeah the code comes on when in higher rpms. So maybe it's too rich or something?
Old Apr 2, 2019 | 09:54 PM
Engine: Lb9
Transmission: M20
Are you getting a code 45 ?
A new o2 is cheap and easy to start with.
Old Apr 3, 2019 | 08:28 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
but if you're going to buy a new 02 sensor, you might want to go ahead and get a heated one.
Old Apr 3, 2019 | 11:28 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Why the heated one? Have a part no.?
Old Apr 3, 2019 | 11:34 AM
Engine: Lb9
Transmission: M20
Amazon, acdelco afs-74 . It will warm up faster for closed loop operation.
you can hook the power wire to fuel pump wire at the relay.
https://www.ebay.com/itm/TPI-TBI-3-W...AAAOSwJcZWcLb5
Old Apr 3, 2019 | 12:49 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
like tuned said "With headers the o2 can cool off and not go into closed loop. This usually happens at idle though."
a heated 02 sensor gets it and keeps it up to temp and in closed loop where you want it.
Old Apr 3, 2019 | 12:55 PM
Engine: Lb9
Transmission: M20
iroc_cragg
Jun 2, 2003 02:10 PM
BOTTLEDZ28
Apr 28, 2003 07:46 PM
TorqueMonster
Apr 15, 2002 03:17 PM
craiger
Dec 31, 2001 11:22 AM
CamaroX84
Jun 11, 2001 11:42 PM
