2.8 turbo
2.8 turbo
ok i think maybe this spring break me and my father are going to put a small turbo charger on my car maybe like a 5lb boost, i have a 2.8 and i donno i like that little motor its nice, it doesnt smoke at all, that car starts right up, but i wanna add a few horeses to it and get my feet wet in turbochargers, but i think we are going to do the low buget thing with this project, but i wanted to clear a few things up. 1. can i mate the turbo up to my throttle body or do i need a new intake? 2. does any one know of any companies that sell a cheap turbo exhaust manifold i could use, i got access to a welding machine and a pipe bending machine. 3. incase i find a cheap decint turbo at a junkyard thats in good condition, does anyone have any tips or things i sould look fr on the turbo, and is there a way to see howmuch boost it will give me? thank you and any input will be grately appriciated.
and i thought i might send out a picture of my bird!, ps this is an older pic of my car before i waxed it and cleaned it up and everything so this pic doesnt do any justice to it.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Welcome, & before you get yelled at, use the search feature. all your answers can be found there.
Also scroll own, this topic has been brought up before.
Nice car
Nice car
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
I do not know much bout the subject. I would say after getting the turbo, do a rebuild of it. The rebuild kits are $75, and would be well worth the efforts rather than having to pull it back off and rebuild it later.
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Originally posted by fly89gta
exactly, the bottom end on a 2.8 isn't all that strong, you're asking for trouble with any kind of power adder on the stock 2.8 bottom end.
Car: 2018 Camaro SS
Originally posted by Camaro_hunter_d
In 89-90 they had a turbo charged sunbird? that had the stock motor minus low comp pistons that had 12-15 PSI. The stock bottom end CAN take it.
And ughhh 15 PSI? u sure about that?
and we all know how reliable the sunbird was
Car: 2018 Camaro SS
So I have been told by a person that has swapped the motor into his 92 cavalier, he is also running 19 PSI now too... has swapped pistons down to a 7.2:1 ratio.
7.2:1?? holy ****!!! i thought the TTA motor having 8.0:1 was low but 7.2???? damn...stock turbo?? i'm sure he has NO power without that turbo spooled up. Stock bottom end and stuff? what's he running?
And with the T3 Exhaust housing he's has boost at 1600 RPM's... So yes the V8's have him at the line... 60 feet later side by side... after that well.... they better have NOS...
The only thing he does not like about it is the 5 speed trans he has to run. Auto won't take it... he's tried... a week later he was putting the 5 speed back in.
Car: 2018 Camaro SS
a 6 pt cage??? for what?? u said he can beat 13.9 Irocs, that certainly doesn't warrant a cage....i'd like to see some timeslips, and some sounds that car house to sound pretty cool
Engine: 5.7 / 7.4
factory 7.6 cr was enough for my 76 bonneville. It'll do high 16/low 17 now. not too bad for a 26yr old car, origonal-never rebuilt-engine with a car that weighs over 4500 lbs w/no passengers.
Car: 2018 Camaro SS
the track in VA(where I used to live) said that if you went faster then 14 they want you to have a 6 point(that track had all kinds of BS rules
that's a retarded rule...
whats the white car in the picture...
looks like a 2.8/3.1/3.4 in there (a Fuel injected 2.8 intake manifold)
he seems to have twin turbos in there
but its real funny the way he seems to be feeding the intakes from the outputs of those turbos...its like a T connector close to the intake (I was under the impression that a Y pipe was needed there)
hey firearm where didya get that picture from?
and hunter looks like that car has ****load of space on either side unlike our camaros lol then that header thing wouldve been a breeze ...big bends wouldve been just ok...lol
I think that white car is a Datsun 510. That is such a clean install.
Say, if the rice boys can get 200 plus hp from stock internals, can't we expect the same from a rebuilt two-eight? The cover of Turbo Performance mag last month had a HUGE hp Talon running a stock block and crank, and all this 2.8 guy is asking for is 5lbs. of boost. Sounds to me like there is a market for hi-tech parts for our cheap Bowties and Shields. Don't forget that this motor was also offered in truck bodies, and that Buick has a huge turbo aftermarket for wheelstanding Regals and GMC had it's version, the four-scratch-mark Typhoon.
Like the rice bumper sticker says, "Got Boost?"
Bill
Louisburg, NC
Bill
Louisburg, NC
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Why make it complicated?
Just get a running 3.4, slip it in, add nitrous and have fun.
So simple!
Back it up with a time slip.
What is the least expensive NOS system I can buy?
Besides used?
I assume, the tank I can buy used, tho.
Wish I didn't have to rebuild three cars. I'd do it and go to Carlsbad to have fun.
Sea level racing.
Who is down by Carlsbad? Anyone?
So simple!
Besides used?
Sea level racing.
Car: 1986 Firebird
Engine: 2.8 V6
) Supreme Member
Car: 2018 Camaro SS
you are correct tom, and the rule makes sense, but a 6-pt cage for a freakin 14 second car?? that's just going a bit overboard
