Greg Weld Pro stars on a 3rd gen
Anyone have actual pictures of Greg Weld pro stars on a 3rd Gen? I have searched and the only picture I can come up with is a 4th gen that has more BS than our 3rd gens. I am looking at a 15 x 5 and 15 x 10 5.5 BS combo however any combo pic will work.
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Re: Greg Weld Pro stars on a 3rd gen
y friend has the 15 inch greg welds on his mustang ...pretty much same backspacing...they look horrible due to the big lip that the wheel has in a 15 inch size...with a tire on it ..looks like a coffee can with a rubber around it....17 inch will look a lot better....
This is the first thing that I have heard that was bad about them
Car: 87 IROC Z28
see what im talkin bout ...or am i the only one that notices that
Car: 99 Z28 / 68 Skylark
Engine: LS1 / 455
Parasouth do you have any pics directly from the side?
Preferrably the full side. How wide are your rear wheels and whats the backspace?
Are they slotted like uni-lug or is it just the 1st picture.
Did you have any problems with the front centercaps as it looks like TPI383 did?
I really dig the dual exhaust on your car.
Thanks to both you guys for your help.
Engine: LS1 / 455
They have 2 different sizes, 4.5 and 4.75 built in, for easier ford/chevy swappage.
Tires are 275/60/15x10
And yes, you will run into those problems unless you get spacers.
However Weld is apparently in the design process for making larger caps.
Car: 91 Z28
Engine: 6.0 LSX Single turbo
Transmission: 4l80E
Axle/Gears: Moser 9" 3.55
I know this is and old thread but has anyone used these 15x5 fronts with ls1 Brakes?
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
