Will 285/40-17s fit in the rear of my '92 RS? It's been asked 1000 times I know.
Old Aug 23, 2011 | 12:37 AM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
I know it's been answered 1000 times, but will 285/40-17s fit in the rear of a '92 RS or will I have to worry about spacing? Thanks, and NO BS. Just answer the question.
Old Aug 23, 2011 | 12:47 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Will 285/40-17s fit in the rear of my '92 RS? It's been asked 1000 times I know.
Yes, they'll fit.
Old Aug 23, 2011 | 12:51 AM
Car: 1992 Camaro RS
Good. Cause they cost like $250 each (taking into account installation, tax, insurence, etc...)
Old Aug 23, 2011 | 12:56 AM
Car: GTA
Just get the bs right depending on a 3rd or 4th gen & your golden.
4.5"bs for a 3rd gen rear.
Old Aug 23, 2011 | 01:02 AM
Car: 1992 Camaro RS
Going to ask a novice question now, What exactly is back spacing?
Old Aug 23, 2011 | 01:24 AM
Car: GTA
It is how wheels used to be measured from the day there were created until the 1990s. Then the imports screwed that up & all the manufacturers switched over to the Euro/Import crap way of saying Offset.
BS (backspacing) was simple. Take a wheel, lay a straight edge across the back lips. Measure from there to the hub mounting surface & BOOM! You had the backspacing.
Now you have to do the same measurement but in Metric, know the width of the wheel, then do some match with the width, that measurement & figuring out what the distance is between the measured bs & the width of the wheel. Backspacing was a SIMPLE thing that my 9 yr old could have found. They screwed it up going metric & Offset!
https://www.rsracing.com/tech-wheel.html
Old Aug 23, 2011 | 01:28 AM
Car: 1992 Camaro RS
Thanks man. That's some great help. Don't know where in Texas you are, but you should come over here to Katy for this event. https://www.thirdgen.org/forums/sout...cle-super.html
Old Aug 23, 2011 | 01:32 AM
Car: GTA
A little north of Austin.
Old Aug 23, 2011 | 01:35 AM
Car: 1992 Camaro RS
That's only like 4 hour drive haha. Austin is a cool place.
Old Aug 23, 2011 | 01:40 AM
Car: GTA
Well....1 hour to get to Austin, 4 hours to get to Houston. 10 hours round trip PLUS the time there? Definitely an overnight thing which means a motel room (or sleeping behind the gas station in my car. been there, done that!)
Old Aug 23, 2011 | 01:44 AM
Car: 1992 Camaro RS
I know, sounds like fun right? Haha. I'll upload photos of what you missed.
Old Aug 23, 2011 | 01:52 AM
Car: GTA
Can't wait to see your paint job in person at next years Roundup! You will come, won't you?
Old Aug 23, 2011 | 01:55 AM
Car: 1992 Camaro RS
Where/when is that?
Old Aug 23, 2011 | 01:59 AM
Car: GTA
Where/when is that?
Date for 2012 is not set yet, but here is a link to this years show.
https://www.thirdgen.org/forums/sout...statewide.html
Old Aug 23, 2011 | 02:08 AM
Car: 1992 Camaro RS
Ooooh yah. That sounds awsome. I have college then, but I should be able to work something out. I should have alot more stuff done to my car by then too. I'm thinking full exhaust, open air element, ultamate TBI, better intake manifold, rear end gears, maybe some heads.
Old Aug 23, 2011 | 10:54 AM
Car: GTA
Open air element cleaners look cool, but aren't the best option for performance since they just feed an engine with the hot air from under the hood. Colder air has more oxygen & makes more power.
Put on a Cold Air Intake system & the engine can breathe better and make more power.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
kah992
Aug 19, 2015 02:55 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Exxon Limited
Aug 9, 2015 08:13 PM
